Hi All,
interested in purchasing the crow cams below but out of stock. Have found a kelford cam but want to know how the kelford cam compares to TX2 or TXM.
Kelford cam specs are:
cam 274 or 226-F
i need to know the duration at 0.50 of inlet and exhaust like crow cams, kelford cam only has valve lift duration at 1mm.
could someone please work it out so I can have the specs like the crow cams.  Need to to duration at 0.50 of intake and exhaust. TIA
Edited by VL_Turbo
Oh. For f**k's sake. 50 thou is 1.27mm which is so close to 1mm that you can just pretend that it is the same and the worst that can happen is that the duration measured at one of them will be a couple of degrees different from the other.
The guy at Kelford probably should have heard about measuring duration at 50 thou because he works for a cam manufacturer and 50 thou was the standard for a million years, but it is totally understandable that he doesn't know because he is likely <30 years old, lives and works in a country that has been metricated since before 1970 and will only be using SI units in their manufacturing process because they are civilised and not trapped under the weight of 300 years of 'Murica f**k Yeah yeehaw freedom units like Crow f**king Cams is.
  • Like 3
  • Haha 2
I like the way crow cams can't spell medium.
Out of curiosity what exactly are you comparing the cam specs to? Each other or some calculated desired valve timing events you have already figured out?
How much piston to valve clearance do you have to work with?
I just thought of this & thought I’d let you know, the good news is the above camshafts do exist, but will they snap?
get the specs off the Kelford “turbo” cam from golbeys & regrind your genuine one to those specs. clivecams, surecam & Marshall custom cams do reginds.
    • Has equal chance of cleaning an AFM and f**king an AFM. I think you can work out what happened. When the Hitachi ECU sees the AFM die and goes into the associated limp mode, then it will start and run just fine, because it ignores the AFM and just runs on idle maps that will do what it needs to get it going. But there is no proper load signal, so that's about all it can do. My suggestion? If you don't want to go full aftermaket ECU, then get some R35 GTR AFM cards and some housings to put them in, in the stock location, and Nistune the ECU. Better to do a good upgrade than just replace shitty 40 year old tech with the same 40 year old tech.
    • So my car was recently having trouble starting on initial crank, I would need to feather the gas for it to start up but besides that it would start and run fine. So I clicked the idle air control valve (with throttle body cleaner) and cleaned the MAF sensors (with MAF cleaner). The start up issue was fixed and now the car turns over without the assist of the throttle, but the car is in limp mode and wont rev past 2.5k RPM. From what I understand the IACV would not put the car in limp mode, so I am to believe it is the MAF sensors, but it was running fine before and now I cant get it out of limp mode. I cleaned the MAF made sure the o rings were seated properly. Made sure the cables were plugged in properly, the cables also both read the same voltage. Does anybody know why this is or what could be causing this or how to get it out of limp mode?
    • Ooo I might actually come and bring the kids, however will leave the shit box home and take the daily
    • Thanks. Yeah I realised that there's no way I'd be able to cover the holes with the filler, it would just fall through. Thanks again @GTSBoy!
    • That was the reason I asked. If you were going to be fully bodge spec, then that type of filler is the extreme bodge way to fill a large gap. But seeing as you're going to use glass sheet, I would only use that fibre reinforced filler if there are places that need a "bit more" after you've finished laying in the sheet. Which, ideally, you wouldn't. You might use a blob of it underneath the sheet, if you need to provide some support from under to keep the level of your sheet repair up as high as it needs to be, to minimise the amount of filler you need on top. Even though you're going bodge spec here, using glass instead of metal, the same rules apply wrt not having half inch deep filler on the top of the repair. Thick filler always ends up shitting the bed earlier than thin filler.
