Freshly rebuild rb25det s2 has no compression! Was sitting in my shed for 6months (nice dry shed and every hole in motor was plugged).
I brought it from a well renowned motorsport guy who had it built for me (bit of a deal for a Neo head i had) i had also brought a Jerico wc4 dogbox off him 2 years ago...
Timing was good checked it over a few times, compression test came up 0-5psi...
Any help would be great!
You would confirm with another gauge, and confirm cam timing is correct, then pull the head off for a look.
 There is no trick or shortcut.
For all cylinders to be super low I would be thinking it is something silly.
Is it possible the camshafts are 180° out with the crank? Timing marks all line up correctly but as the crank rotates double the amount as the cams then could they be 180° out?
I've just purchased a leak down test kit so will wait for that to arrive then do that.
Wouldn't cause no compression. It would work exactly like it should, except it would be trying to spark at TDC on the exhaust stroke.
Although that depends on what exactly you meant by "180° out". 180 crank degrees or 180 cam degrees? 180 crank would be weird, but timing marks wouldn't line up. would need to be 360 crank for the timing marks to line up.
I mean when checking the timing i noticed that when i put the crank on it's timing mark, both camshafts timing marks were on the opposite sides of what they should have been so then i spun the crank a full 360° untill the crank was back on it's mark again and now both of the camshafts were on there correct mark, so when assembling the eninge how do you know when your not 180° out? They guy i brough the motor from done the timing so i wonder if he has got it wrong?
The same as on any engine. TDC compression on cylinder #1 is when the piston is at the top (easily found by timing mark on crank if correct, or by feeler rod through spark plug hole if suspicious of markings) and the #1 cam lobes pointing at the sky.
TDC on exhaust, the cam lobes are pointing downish. The exhaust cam will be close to closing and the inlet cam will be close to opening.
We don't talk in cam degrees. There is no "180 out". You are talking about 360° out, engine degrees. And as I said, if it was 360° out, you would still get compression. All the mechanical things are still working in concert. TDC is still TDC. If the inlet valve opens just before TDC, then the engine will still ingest air. If the exhaust cam is closing at that same point, then the air will still be trapped inside the cylinder and get compressed on the next upstroke. Etc.
The question of whether the engine will run or not will depend on how the ignition is timed wrt to the engine. If it was a crank driven distributor then it would attempt to fire on the wrong stroke, while the valves are on overlap. Not going to run. If the ignition timing is driven from the cam (like it is on an RB) then the engine should actually run. It's just that all the marks on the timing chain won't line up when they're supposed to so you'll have to have it 360° out to get them to line up.
But, regardless, your lack of compression is far more likely to be either all teh valves are bent/stuck open, or you have another severe cam timing error (other than 360° out), if it is even possible to get it that bad.
Ok cheers thanks for the clarification!
Thanks for that picture, yes all i checked timing correctly as per picture with the harmonic balancer removed aswell to be sure.
Have just done the leakdown test (had to rush back to work) i mananged to quickly test cyl 1&3 each at TDC and the air was rushing out of the exhaust side and out the exhaust, couldn't hear anything from intake but next time i test I'll remove the intercooler to listen properly
    • Just read this... Just a little bit of a wild one! Do you think the driver was testing out a new feature/device for how to lose the cops in a high speed chase?   I also suspect, if the box has a road sweeper that does magnetic metal pick up, he does a LOT of work in the machining industry. Which is what most of that looked like, machining chips from a mill or lathe. And I bet they're RAZOR sharp! And from an environmental perspective they really do need to actually collect all of those little pieces too. I wonder how many people still cop flat tires over the coming months on that road?   As for insurance company, yeah, it'd be interesting to hear what they say to the owner. But realistically, he's right, that "It's his fault". In the way that, it was his truck that spilled it, so they need to clean it up. However, neither he, nor his insurance company may bear the end cost if they do an investigation and find out it was caused by someone elses negligence (And they know who)...
    • Yeah, no matter what bad things people can say about Julian from Autospeed, he at least was capable of thinking and his inclusion of a check/relief valve in the plumbing for the Audi boost controller, that I made a copy of and used for years**, completely eradicated that problem. **It's still lying on my workbench where I put it about, um, 18 years ago and have never found a home for it!
    • I didn't actually know this! I've seen photos of the H1, mainly outside shots, and they just look "different". I guess there'd be a few little changes like nicer rims, and probably the fact they have nicer looking paint with some depth and shine, which will make any vehicles body look different to the very flat colours of the defence force.   I've watched the guys on GHPC convert their Humvee to LS1, and they've done some really nice front shock upgrade. I'm waiting for the next video on it with the rear end done. I can't remember if they've already done it, or I dreamed it, but I believe they're also supercharging theres. They will be in the future doing proper long travel suspension too.   If you ditch out your big V8, as rubbish as it must be, send it to my place. I'll let the unreliable V8 motor and box be here. I just like V8s... So I'll find something to do with it... Even if that something is just taking up valuable space in the yard. I might have something Skyline I can send back in payment... Or even Ford Barra motors  (From memory you're in Canada yeah?) So you can then play with the legendary Aussie 4L version of an RB...  Except they don't have that distinctive random miss at idle like the RB25 does.
    • Or you mean the age old problem of early 2000's manual boost tees, where they never let the pressure out of the line between the boost tee, and the waste gate, so after your first trip on boost, the damn wastegate liked to stay open and be laggy on gear change?
    • Being behind an RB25DET, we know he won't have the small box for long at all...
