Cam cover off, exhaust manifold off, bright light in through spark plug hole, inspection camera in through exhaust port, looking for light coming in around valve seats that should be closed.
But yes, probably easier just to proceed straight to head removal. Possibly find what you did wrong with the cam timing (to cause bent valves) as you disassemble!
Do you know if the motor had comp & was running before you swapped your neo head for it?
to me it sounds like it’s a rb25de converted to rb25det. Check engine number to see if this is the case.
if it is de… I’d say it’s still running the de piston & rings, that aren’t sealing the comp for the turbo setup.
Oh, is this based on your research for the (admittedly helpful) reply in the other thread about the difference between Neo DE and DET pistons and rings?
If so, what makes you think that the difference between the DE and DET ring packs is how good they can seal? Can you not imagine another reason that they might be different? Maybe the ring grooves are different dimensions between the turbo and non. Maybe the Nissan engineers (rather obviously) acknowledged that the turbo application was a harder duty so they had a more resilient ring pack design.
Because, as you surely must know after all this research, there have been literally thousands of DEs have a turbo slapped onto them, and provided they are otherwise built and tuned right**, they do not suffer from weak ring syndrome.
**Not to be taken for granted, because the world is full of morons who just slap shit together and wonder why it blows up.
  • 2 months later...
26 minutes ago, Driftieboy said:
Update, the shop that done the rebuild f**ked up big time, machine work on the vavle seats was done wrong and the bearings were also installed wrong so my freshly rebuilt motor in now getting another rebuid 🥴
Is it all being done under warranty?
  • 1 month later...
Unfortunately no...  i was slack and because of family life it took me 2 years to put the motor back in and all finished up ready for it's first start... turns out my "6months" was abit off 😅 time flies when you have young kids!
Edited by Driftieboy
  • Sad 1
  • 2 months later...
Sorry to say, the only thing I would ever do
iN tHe bIn! : MightyCarMods
No matter how expensive the oil cooler and lines are, losing another engine is more expensive.
Also don't forget the oil/water cooler at the block if you still have it, and also the inside of the oil pump if you are re-using that
Teflon lined hoses? They shouldn't hold on to any metal bits, because they're pretty smooth. Just a damn good flush with lots of water and possibly then some solvent. If paranoid, you could try to pig them by pushing through something (fabric wads, earplugs, tampons) with a skinny and long enough rod. Or you can attempt to pull them through by attaching same to pull wire that might be easier to pre-thread on a longer hoses.
Cooler? Throw it away.
Thanks, yeh inside of hoses seem nice and smooth, i ended up fulling up a water bottle with diesel and squirting it as down each line with some force into a bucket, used a good 5L, i attached some photos of the end result and no that's not stars in the night sky! 😅
Anyone want to buy some diesel? Going cheap 🤣
  • 3 weeks later...
It is possible to refurbish the cooler, in the US at least we have some oil cooler service companies that are mostly specialized in aviation and are FAA certified. Those oil coolers are usually huge, huge money because everything in aviation is. They flush the cooler under pressure and high temperature + ultrasonic it until they verify that the cooler no longer sheds debris.
Pig your lines with any appropriately sized rifle/shotgun cleaning kit. As for the cooler, as mentioned, there are many companies that can clean it out if it's actually worth something. If it's a cheap ebay 150$ cooler, toss it.
  • 1 month later...
    • Went to a drift practice day at a local circuit (held on the reserve parking area behind the grandstand) for the first time in about 15 years. Some kei cars were drifting as well, a not so surprising Suzuki Carry truck, and two 1st gen Daihatsu Copens that were converted to rear wheel drive(!) using Daihatsu Boon X4 transfer case, prop shaft and rear diff, obviously omitting the front driveshafts. They looked really fun to slide. I heard that they cost "about half" as much as a Nissan Silvia etc to run.  On the track 'Tech M' a local BMW tuning garage had a customer track day. Mainly recent models but there was one E36 which looked ancient among all the current models. It was cool watching the drifting and then turning around and seeing random people thrashing their M3/4s  central-circuit-drift-practice-2025-05-18-long-yt.mp4
    • I prefer it with those wheels (sacrilege?) 😋 Here's a photo of a fully original one for reference. The price is $350K....
    • I would like to keep it around 15k but if I need more to make it reliable and not have to worry about the car breaking I can go more. It's my project car so I'm just trying g to figure out what needs to be in it i know basic things like turbo cams injectors I'm just unsure of the size and the specifics so I'm spending alot of time on Google and its mostly rb25 and rb26 not alot on neo
    • This. They would need some tricky maneouvering to keep the income out of the country (the US). Which isn't helpful if that's where you want the income to end up.
