So I have the car in the title, and I love that the side wing, rear view mirrors dip / point down when the car is in reverse. And as expected, they *attempt* to revert back to the original position, but fail. They appear to overshoot, and I have to manually adjust them back into position. Normally they return with a angle pointing slightly into the sky 😠
I know I can turn off the tilt on reverse, but I find it very useful when reversing out of my VERY tight garage.
Is this normal or common?
I tried the window reset type procedure. ie move to highest then to lowest. And it did not change.
Any other suggestions? Is there another trick?
I never had this problem in mine.
What about using the seat position buttons?
Don't they remember steering wheel and mirror positions?
It's not a fix but im thinking you could just press the memory button to return it to your preset position
Mine is a 2008 370GT SP Coupe,. and I have never experienced any seat position memory/return. It does not have the 1-2 buttons on the door, for different driver's. Are they the "seat position" buttons you are talking about?
I drove yesterday, and I noted that the passenger side actually returned pretty much spot on and did not need adjustment after reversing. But, the drivers side did after every reverse. Its not a total killer, as I leave the "side control" turned to the drivers side, and its becoming almost a muscle memory to tilt it down again after reversing. But obviously still not the best way to be.
4 hours ago, V35_Paul said:
yeah.
Maybe my memory of my car is wrong. I did have 2011 V36 SP, maybe in the newer model it had them.
It was also an option on the earlier models, and another being heated seats.  I saw some when targeting my year. Neither of which mine has.
    • Hi All, I have a 32 GTR, with coilovers, hicas lock bar, exhaust and pod filters. Just after suggestions on where to begin with engine/power output mods without breaking the bank. Thanks in advance.
    • I’ve been considering one of these screens too, but I've heard mixed reviews about the software responsiveness. Some say it's great, while others mention lag issues. Before pulling the trigger, I'd check out a few recent user experiences to see if the latest models have improved.
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
