On 2/4/2023 at 5:39 PM, GTSBoy said:
You need to keep the 3 circuits separate. You either need a double pole and single pole switch, or a triple pole switch.
My headlights are working. My high beam dash light is always on. If I turn the High beam on or off there is no difference. Are there separate high beam bulbs? Are they the inner bulbs on the light?
Yes. The low and high circuits are completely separate, but that switching is done at the column switch.
The binnacle switch has left, right (headlights) and parkers. The left circuit is switched back and forth between low and high beam, at the column switch. Ditto the right.
The low beams are the projectors. The high beams are the plain globes in reflectors inboard of the projectors. They are not supposed to be on at the same time**.
So, I would suggest that you have a problem in your column switch also. Or, possibly someone had f**ked with your wiring, in an attempt to have the low beams stay on when you go to high beams, without doing it properly (as described in my footnote below). The consequences of not doing it properly will cause too much current to be drawn through the switches, which could certainly lead to the binnacle switch running hot and causing the damage you had in there.
** FWIW, you could alter the wiring so that the lows stay on with the highs. This would require some relay and diode logic down at the front of the car so that the low beam relays (added, not stock) pull in when low beam is selected, and also when high beam is selected. This would just be a link between the high and low wires coming down to the front of the lights from the column switch, with a diode in it so that the low side does not also run the high side, but the high side can run the low side.
    • Where is the best location for boost pressure source when running mac 3port boost solenoid?  my new turbo does not have a fitting for that on the compressor housing.  how come Garrett make a turbo without that?  im confused
    • From my memory, which isn't that great, we did have issues getting the large throttle body on my old LS1 to play nicely at idle, first it would stall, then it would only idle at 2k rpm, then it would hang at 2k rpm for a few seconds and then drop and stall, then, finally, the best we got was it would hang at 1.5k rpm for a few seconds then drop to around 800 rpm The tuner stated that large cable throttle bodies are a PITA, and if I wanted anything better than what we ended up with I would need a electronic throttle body and all of the aftermarket ECU stuff to run it
    • So, my intake arrived  I'm not happy with the coating finish so I went to Supercheap and got some black wrinkle paint and some prep stuff I was initially thinking about using grey wrinkle paint, but finding a quality product that gives the texture I want was "unfindable...", so the tried and tested black wrinkle paint is again finding its way into the engine bay for the OEM look I'll sneakily head into work and get the big ovens cranking to cure the paint over the next week or so I've also contacted MX5 Mania today to talk about the install and tune, so painting it is my "main effort" prior to sending the car off In other news, the correspondence from the US supplier is fair to midling to say the least, I'm still trying to track down the intake box thingie with the larger intake pipe to suit the throttle body, it still is "awaiting fulfilment" (no stock currently available), if it isn't here soon I'll just get MX5 Mania to fabricate up a CAI that is easy to service the air filter
    • Thanks mate. I thought it would be that way.
