Hi all, I’m in the middle of restoring my R32 GTR and have heard that the stock g sensor under the center console is prone to age and uses antiquated technology. Has anybody used the Do Luck digital g sensor with any success? Or any recommendations?
I’m also curious if this unit would affect the stock ambient pressure in the attesa pump, because I would like to wire in a switch to the AWD fuse to go into RWD only on the fly, and I understand this only works with the R32 system that has no ambient pressure. Anybody can confirm?
Thanks
https://www.sau.com.au/forums/topic/484566-r32-gtr-do-luck-digital-g-sensor/
Thanks
The g-sensor of the R32 won't affect whether pulling the fuse disables the system. The R33 + R34 uses a failsafe solenoid to do what you're talking about.
the switch in an R32 prevents power transfer to the front, most of the time it is in RWD mode. R33's and R34's use a second solenoid to maintain residual pressure in the pump so that the power transfer is faster, hence why you can't just kill it by pulling the fuse or wiring a switch in-line with the fuse.
the G sensor's PWM is not the issue, the transfer of power to the front is mostly affected by the speed of the ATTESA pump... hence why in subsequent models they upgraded the pump system.
my personal opinion is that upgrading the G Sensor is snake oil and a waste of money. once you turn off the solenoid you have to restart the car to make it active again... which is not something you do in an ordinary driving situation. You'd only flick the switch to do skids, some drifting or warming up tyres for drag or a 2WD dyno. In all those scenarios the speed at which you disable ATTESA is irrelevant.
There are cheaper ways to intercept the PWM duty cycle from the sensor so it's not a permanent off till restart, these days you can use an Arduino for IO, about 20 years ago we used $50 circuit boards from JayCar. It's definitely not as exxy as $500+ for a Do-Luck unit.
The G-sensor is just a replacement for the old factory sensor. MEMS reacts faster and probably more accurately than the old sensor design. To my knowledge all it can do on top of that is fake the sensor response to make the ATTESA system think there is more or less friction coefficient on the road at any given moment to reduce or increase the AWD. People in my area have reported decent improvements to driveability in autocross so it's probably not a waste of money.
I dont know what the stock g-sensor is like because my car didnt come with one. The previous owner in japan already removed it. But i installed the doluck sensor and noticed the car handles noticeably better in AWD than in RWD.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
