Hello all,
I have a 1996 Skyline r33 GTS-T.
This question is a two-parter.
Firstly, and more simply, my r33 has GT-R Brembo Brakes. I am buying new pads and rotors. Can I correctly assume that any GTR-Brake/Rotor that was originally compatible with the r33 is going to be the same shape/size, regardless of the model? By that I mean, without knowing exactly what GT-R model these Brembo brakes came from, I can safely buy r33 GT-R sized brake pads and rotors and should be fairly safe in them fitting correctly?
My second question is a bit more complex. I do not know if the previous owner put in Glycol-based brake fluid (DOT 4) or Silicone-based brake fluid (DOT 5). I did a test, by extracting some fluid from the reservoir and adding water. The brake fluid and water DID NOT mix, implying it is Silicone-based, but also the brake-fluid isn't purple, which is really throwing me for a loop.
So, to be absolutely safe, I've decided instead just carry out a full fluid flush and replace with Glycol-based, especially since I am putting new pads and rotors on anyways. However, I am uncertain as to what the best method would be. I have read that I should use denatured alcohol (methylated spirits) to push the original brake fluid out, then use cheap DOT 3 to flush the system, then put in my proper high quality DOT 4 or DOT 5.1 brake fluid of choice. Is this correct? I've never done this before and want to make sure this is a proper method. I've also read that I should use compressed air to fully flush out the denatured alcohol, but I'm sure I understand how that works? Would I just hook up an air compressor pump to the brake fluid reservoir and open all the bleeder valves?
I appreciate any/all advice, links and sources, and information you can provide.
Thank you
https://www.sau.com.au/forums/topic/484570-need-r33-gts-t-brake-advice/
Yes, the Brembo brakes across R32 Vspec, R33 and R34 GTR are all identical sizes and pad shapes, I think the colour might have changed in R34 but they are the same otherwise. They all run a 324x32mm disc (which we'd refer to as DBA 4928/5928) and a DB1178 pad
Same story in the rear, they are the same across R32 vspec, R33 and R34 with a DBA 4929 disc and DB1521 pads.
If you can't cross reference those numbers in the UK, the dimensions and pad samples are on the DBA website.
Re the fluid, I've never come across DOT5 in the wild, it is highly unlikely to be the case. When I get a new (used!) car I just flush the fluid out with 2 bottles of general DOT3 or 4 (whatever is cheap) and then put in whatever I was after for that car (generally Motul RBF600 if it is performance or race use)
Using 2 different coloured brake fluids makes it very easy to do a complete flush as well.
Say the proper fluid you want to run is yellow.
Start with a cheap yellow DOT 3/4, then flush with a cheap blue DOT 3/4 and then finally use the brake fluid you want to actually run, keep flushing until the blue is gone.
A word of caution. Unless you were explicitly told that they are GT-R Brembos, they could also be from a Z chassis car (or slightly less easily, from some other car altogether). My caution might not be necessary, because the pads could be the same anyway, but just on the off chance that the calipers is different and has a different pad, double check the pad dimensions before committing to anything.
Thank you! That puts me much more at ease and I feel a bit more confident making my purchase.
I'm really unsure. On the one hand, this stuff isn't purple (see picture), the factory cap says to use DOT 3, and upon messaging the previous owner, he "thinks" but does not for sure remember putting DOT 4 in. On the other hand, the extracted brake fluid does not mix with water (see picture), and at the suggestion of another forum post, I rubbed some of the extracted fluid between my thumb and finger, the extracted stuff felt slick (which I was told indicates silicone), DOT 4 by comparison does not (has a grainy feel to it). I have also read that DOT 5 can change color to yellowish over time.
I keep wanting to second guess myself, because as you have said, it's rare to find silicone-based brake fluid out in the wild, but the more I think on it, the more I think DOT 5 is what I have.
I agree, and that makes sense, my concern, is what happens if I have silicone in my system and want to replace it with glycol. I read that an alcohol flush does the trick, but others have said that you have to replace every hose, the master cylinder, etc, etc, every part, because if any remnant of silicone remains, it can destroy your braking system.
I am fairly confident they are GT-R Brembos, as they were listed as such when I purchased the car, but regardless I agree it's a good idea to do some measurements before I commit.
Edited by IXMandalorianXI
I have no idea what they charge, but if it's cost effective, maybe send some brake fluid off for testing?
https://www.savantlab.com/applications/brake-fluid-testing/
If it's reasonably priced, might be worth the peace of mind.
If he put DOT5 in those brakes you can flush it by using methylated spirits/denatured alcohol. Fill the master cylinder reservoir, use a cap that holds pressure to pump 15 psi through the system, open up a bleeder and push all the fluid through until you're 100% sure you have nothing but alcohol coming through the lines. Repeat for all bleeders in the system. Then run the ABS pump using a scan tool to make sure there's no brake fluid stuck in the ABS actuators either. Then repeat using DOT3/4/5.1 until you get say 200 mL of clean brake fluid out of each bleeder. The process is going to take forever but should be ok. I recommend using a pressure bleeder because like I said it takes forever and you the owner is probably the only person with the patience to deal with this ordeal.
I would be concerned about seal compatibility in the system but what's done is done. Flush it and see if anything fails.
  • Like 2
Many thanks for the detailed instructions!
As far as I know, the r33 doesn't have ABS, so that should simplify things a bit.
What do you use to pump pressure into the system? Just a pump with an adapter cap for the reservoir?
UPDATE: Did some googling and turns out these pressure kits with (mostly) universal caps are easy enough to find online.
This looks like a simple enough process, just need patience and to take my time to do it right. In the long run, I'd rather have DOT 4 in here than DOT 5, I think.
yeah the only trick is to get the cap that suits your master cylinder. I use the SP Tools one. https://sydneytools.com.au/product/sp-tools-sp70809-25l-brake-clutch-pressure-bleeding-kit
The other option is vacuum bleeder but you still need to attach it to each nipple rather than once at the master cylinder.
Either way, if you use a pressure bleeder you need to be careful not to empty the master cylinder and suck air in because it is a bitch to clean back out
  • Like 1
New rotors and pads have arrived! Just bought a bleeding pressure system, some denatured alcohol, some cheap DOT 4 to flush and some high quality DOT 4 for the final fill. Got a 4-day weekend this weekend and access to a lift.
This thread took me from being extremely nervous and willing to pay someone to do this for me to feeling confident in doing this correctly myself.
Thank you everyone for the advice and information!
  • Like 2
    • I swear at my GKTech ones every time I have to take them apart and replace a spherical. But I wouldn't swap them for anything else. They absolutely slay every other option, at least in terms of how they actually work. You sure you don't want to live with bearings? I mean, they don't have "ball bearings". They are rod ends and sphericals throughout. Tough as nuts, even though I have found more than one way to wear them out.
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
