  On 04/04/2023 at 12:17 AM, GTSBoy said:
I read it as new chat thread and wondered what was wrong with the old one.
Expand
The old one was in the members section and the old members were removed from there so now we have this one to stay in touch
https://www.sau.com.au/forums/topic/484574-nsw-chat-thread/#findComment-7977828
  On 04/04/2023 at 5:31 AM, deongster said:
Duncan why do you have so many things for sale!
Expand
Ha! That thread has been up since you last logged on.
I have a bunch of other stuff to move, wait until the internet finds out I have a working Epson EJ1 I don't need.
https://www.sau.com.au/forums/topic/484574-nsw-chat-thread/#findComment-7977844
  • 1 month later...
  On 04/05/2023 at 11:04 PM, r32-25t said:
@evil_weevil how’s the i30 going? Thinking about buying one myself as it seems like the most sensible of the cars I was considering
Expand
My daughter just purchased a new Kia Cerento GT, "apparently" going of reviews it has basically the same driveline as the i30 N line premium, apart from the transmission options
Both had typically warranty IIRC
She went looking at both, she said they were both similar inside, but she liked the inside of the Kia better and the Kia had a little more room inside
She ended up going the Kia Cerento GT because it ended up a few grand cheaper than the i30 N line premium
She has to wait for it though as she wanted some premium pearly white paint
In saying that, even with the extra costs for the paint and other accessories she ticked the box for, it was still a few grand cheaper
How it holds up long term wise compared to the Hyundai is something that will have to wait and see
They way I see it they are both great cars for girls.....😋😘
  • Haha 2
https://www.sau.com.au/forums/topic/484574-nsw-chat-thread/#findComment-7979014
I had a 2011 i30 manual diesel.
Box in it was what you'd expect from a normal driving car.
Oddly after having the work EV for the last 8 or so weeks, it's weird driving a manual on the street. And I'm not sure I could buy a traditional manual for street duties again.
The Hyundai's and Kia, they're going to pretty much perform the same as each other longevity wise. Most of the electronics, drives etc are all shared.
I have a lot of technical documentation from Hyundai, and it's all headered as "Hyundai Kia".
  • Like 1
https://www.sau.com.au/forums/topic/484574-nsw-chat-thread/#findComment-7979036
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
