On 6/3/2023 at 9:22 AM, r32-25t said:
only gtr I’ve seen was a 34 that was completely stripped on the back of a tow truck, I think it was being restored
Man I miss my old MK III Supra :(
Such a cool car, nothing overly standout, just... That mid to late 80s era!
19 hours ago, r32-25t said:
Is that the same one as everyone else owned?
Nah, I had my one before Zeb bought that one that got passed around.
And I skipped the 7M jokes. I had the pleb spec 1G-GTE, with an Auto... :(
it was still hilarious though, such a slow thing, but would rip one hell of an epic skid on the brake when it finally stalled up onto boost... Standard turbos, but holding the brake and throttle, had to wait about 10 seconds for it to build up boost and be able to start to break traction... Ha ha ha
  • Haha 1
I hated my VA1 STI after I realised I would need to build the engine to get any real power for a 1550kg car safety
20180208_183913.thumb.jpg.ccf1f9bb758217e52016fc4fcada38f8.jpg.3ef98980a631d8d3ef5ddca407d5bc13.jpg
Pulse Racing did the usual mods to it, intercooler, CAI, injectors, turbo back exhaust and a fuel pump, that gave around 215kwatw, pulse said the turbo was then pretty tapped out, and if I wanted more power it would need a bigger turbo, and a built closed deck engine
The open decked, weak rodded EJ25 is junk in my opinion and should never have been used
In the end I just hated looking at it, it started to look like a Kia sedan to my jaded eyes
It was fun blasting it around on some dirt roads when I was working in Amberley though, but not to inspiring on the road
My 86, after I put a turbo on it to get around 215kwatw, was a much better car to blast around the streets in.....until I backed it into a guard rail after hitting some diesel that was on the road at a roundabout that is
I'm still jaded about killing the 86, I still have epic sads about that, and as they only released 60 of them, it makes the sads epic
20180811_171125.thumb.jpg.5f181319a0b48d50b35d8dc10e3f5cdd.thumb.jpg.9d65711b039243a4082f89ed7637e185.jpg
But giving the Bogan Cruise Ship a hit now and then does make me forget about the 86, until my daughter reminds me by sending photos of the 2017 Limited edition ones she sees that is, there is one that lives in Goulburn, every time see see it she sends her poor old dad a photo, I really should spend her inheritance on holidays, expensive sports cars and other random stuff.......that will teach her :4_joy:
  • Like 3
How did you get the RFP1’s to clear the brembos, my son just bought a set for his BRZ and they don’t clear the brembos
I just got the right offset I think
17 x 8 +45
That car had the ej207 engine in it and was a lot of fun, high reving smooth power delivery.
the ej257 is known to be weaker but I have seen plenty making 285kw at the wheels on e85 with unopened engines. Everything I’ve heard is the semi closed (257) engine is good for 300kw before needing to close the deck, with pistons and rods always being recommended
17 x 8 +45 with 235/45 17
No rubbing anywhere, filled the guards great with a little 20mm drop on some MCA coils
20190812_141451_resized.thumb.jpg.420dbd8f9621b9b7fc17752ac1ab06d0.jpg.066d1e63a95cdabe2902ba0d07bfa102.jpg
And look at the red VX SS Commodore in the pic, fate?????
16 minutes ago, Duncan said:
I just wanted to share this effort from Goulburn Mulwaree council
Full marks for resealing the road. Not so much for attention to detail.
I assume no one was looking at the precedences in the construction Gantt chart
I wonder who was doing the project management?
I wonder who was signing off on it?
At least there will be somewhere for a pot hole to start after they move the pole and do the "typical" patch job on the asphalt
Local council ethos: If a jobs worth doing, it's worth doing half arsed.
I cringe everytime our local council fixes a pot hole or resurfaces a road, you just know it will be worse than what it was within a few months
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
