Hello, I looking for stock exhaust pipe:
- mid section Y pipe after the catalytic converter
- the pipe between the Y pipe section to the muffler.
My car is MY08 Skyline 370GT coupe, CKV36.
Thank you very much
Edited by SKL
Typo error
https://www.sau.com.au/forums/topic/484613-wtb-stock-370gt-coupe-exhaust/
