I went to inspect a car and it had finance, now it shows finance from a few years ago and the owner said that it has no finance and he never received an letter or anything. But it shows the registration of the person who had the security interest which isn't the same as the seller's (and that rego doesn't seem to be active anymore), who now has the finance the old owner or the new one? I know usually it follows the owner but it looked odd to me, and shows the finance ends in a few years.
https://www.sau.com.au/forums/topic/484625-question-about-finance/
Well that depends on whether the encumbrance is still current or if it's just a zombie. You need to contact the holder of the encumbrance to find out if they actually do still hold it.
These registers are not always going to be 100% accurate. They serve to prevent as many surprises as possible. Here you have a potential surprise. Investigate.
It's showing this:
I'll give a call to the company next week and if there's no finance get it all in writing.
Edited by silviaz
I have had the ppsr not clear.
Bought a motorbike off a dude, didn't do the check cos trusted him.
I sell motorbike and guy foes check and itnhas finance!
Go visit guy I bought it off as i remembered where he lived , he was as surprised as me *and surprised to see me* and happy to help ( for perhaps obvious reasons, it was in his interest afterall)
Apparently the bank never updated the register. All fixed and no dramas.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
