Hi,
if had the car for around 3000km now. Since the last 750km the transfer case started to leak. I have degreased it a few times and after a drive the drips are already hanging under the case. It’s red of color so I am sure it is ATF fluid. The case or gearbox has not been removed. I did change the gearbox oil to redline to get rid of a grind in fourth, but thats it. What are the most common causes of these cases to start leaking?
Also when shifting I feel the car does a hard clunk even when letting the clutch get up slowly. Its like something gets a snap due to getting power from the engine. If that makes sense.
Hope someone can narrow it down for me. Can’t get the car in the air to verify more. Would need to go to a shop for that.
cheers!
Edited by T.Krol
Spelling error
1 hour ago, T.Krol said:
Hi,
cheers!
Transmission or engine mounts need to be replaced if you get bad shift shock even with a lot of clutch slip. The back of the transfer case is probably leaking where the hose connects. It’s a high pressure hydraulic system so leaks are inevitable with age. To be sure you need to clean it off and then repressurize the system while under the car.
  • Like 1
And while that can be true, it is also possible that the clunk comes from the tailshaft centre bearing, from the diff CW&P lash, from CVs or the splines of the driveshafts into the hubs, etc. Also possible to be in the front drive stuff, but you wouldn't expect anything there to cause much noise on a normal takeoff.
  • Like 1
Good point, there’s a whole class of failures I forgot about that can also cause this.
Thank you. I did read that the clunk noise can have many different causes. I guess the car needs to go in the air to figure that one out. I did go ahead and ordered this product: https://frenchysperformancegarage.com/collections/nissan-skyline-r32gt-r/products/fpg-bnr32-attesa-high-pressure-hose-replacement-with-optional-pressure-sensor-adapter-fpg-116?variant=42829932724402.
Since I am quit sure that the leak is coming from the Attesa hose. Also it might be leaking at the Atessa pump above the read diff, since I do get a bit of oil leaking from the right side area of the rear-diff, also red colored oil.
Is it harmful to drive every now and then with the car with this small leak?
Not if it is actually just a small leak. Just watch your level. But, it could also transition into a really big leak at any moment, and that could be destructive.
so, as I mentioned in another thread on this leak recently, just back off the attessa line where it goes into the rear of the transfer case about 1/2 turn (or 12 turns if I can't type), then tighten it up again. Give everything a thorough degrease and see how it goes.
you can monitor the level of that fluid in the reservoir in the boot, just top it up if necessary
Reservoir was almost at max level without ign on. Topped it off but did a lil too much. I am 8-10mm above max level. Tried to put the ign on and see what it did but it stayed at that level. Is that allright to run the car with a little over max? Havnt turned the car on yet to check the level.
    • Strangely I noticed it either disappear later in the day, or not be present. I definitely noticed when I was crawling around that open wheel thingy entering the pits (that part was audible in car). Driving home and commuting around town for example, I didn't hear it. It's plausible that it was a brake disc or something still slightly in contact. The brakes absolutely felt BAD for the first couple of sessions, huge amounts of shudder and grinding as they got up to temp - And then I actually just forgot about it as the day went on/didn't notice it. The videos were from the morning when this was more present than the afternoon/drive home when it wasn't. I've asked around and got a variety of responses including handbrake shoe contacting hub, CV joints, CB tailshaft bearing as above, and clutch input bearing. I didn't test if it disappeared when clutch was in. I haven't noticed it in any of the other videos nor did I notice it when driving to that extent. More or less hoping the microphone at the rear license plate giving some kind of clue of 'something' but it looks like "spin stuff and see if you can notice it" is the way forward here. I could be smart and use the gopro mic and re-mount it to that location to see if the sound is still present at low speed actually. Sounds like a decent test whenver I have the CBF'ness to drive the car again. Given it's almost 40C for the day of the track day and the next 3 days after, the CBF is high. All I've done since getting home is unpack the car, remove the remnants of the lip and undertray and left it there. I was surprised how well the PMU Club Racers actually worked. The brake performance on the track was absolutely fantastic, best I've ever personally used, no fade whatsoever and the bitiness was almost too good, I was scrubbing more speed off than I needed to, but I also ended up infield when I started trying to scrape off ... less speed.... so...
    • Not really, no. Anything you would do is easily reversible.
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
