Hi.
As of now i dont what happened(update comming soon)...but i just dont WTF was happened.
Head and top of the engine was rebuild last year...it ran great. I ran like 5k with no problems and car ran good when you take to consideration that is kinda slow have 216k km and is old.
But it ran.
Yesterday i took it to a trip and when i was near home i started to smell like burned plastic...i thought it is from outside. But when i stopped at the lights the smoke starts pour from under the car(engine)
So i stopped the car and take a look. My hood do not want to open so i try to look everywhere i could. I stall the engine and after like 10-15 min smoke was gone.
I saw nothing burned nothing smell ...nothing. So maybe some plastic melt or something "plasticy" drop on exhaust. I started up the car and it went good...nothing. No smoke no smell and car ran great.
I was like 20 min from home so i ride.
But after like 10 min i started to smell the plastic again...and of course on the lights there was the smoke again.
Iam not going to push it but i need to stop elsewhere and. Car still runs normally so i ride like 2-3 min to park the car and call the "angels".
BUT then suddenly car make some wierd noise(i was low on gear and it sounded like the car was not happy on low gear and low rpm)...but then again the same noise and car just stalled.
I drifted to side of the road. Car (engine) was smoking.
I manage to finally open the hood.
Now what i found. There was nothing burned. Smoke came 100% from the engine. Car did not wanted to start (cranked 1 times...sounds bad) so i leave it.
The radiator was cold...(like how?) there was no leakage as far i could se. Oil was at the top and do not look bad(was changes like 800km ago).
The back of the car(more near the exhaust side) was covered with oil/fuel? Something oily. But smoke or any type of smoke was really came out of the engine only...no smoke from exhaust(i looked at mirror constatly)
I know "magic ball" but WTF should have happened? Car was at the mechanics like month ago and he checked all fluids and any "service" things and all was good...and car was good runned normally until this happened.
https://www.sau.com.au/forums/topic/484639-cooked-enginerb20de-neo/
@GTSBoy I "IF"...why? The gasket was brand new. Any reason for that? I do not race the car or otherwise abuse it. The whole "trip" the car has seen red(7k rpm) like 10 times max. I know that temperature gauge is not 100% accurate but it was at the center whole time(it should work...it goes down when the car is cold) so idk 😕
@Duncanidk i do not check at the time(my mechanic will) but i kinda dont think so...or at least not "much" cuz when the car stall on itsefl and i manage to open the hood the radiator was cold as no "hot" water was even there 😕 after like 10-15 min the radiator was starting to get warm/hot.
I have done brake swap from GTT so i checked everytime i ride for spillage underneath the car...and no drop. Even my mechanic looked last time(like 14 day ago) and car was bone dry ...no leakage or anything...
So i think something goes horrible wrong...again 😕 I know it is old car and things can go bad but i really dont know why this was happened.
Understood, but unfortunately a key reason for a cold radiator is that there is no coolant in it, it will just be at ambient air temp then....
It is way hard to guess without seeing the car, but coolant can look like smoke and no coolant feels like cold coolant
  • Thanks 1
4 hours ago, Kapr said:
Hi.
But it ran.
Most engine rebuilds are not that comprehensive purely for cost and time reasons. Also when it isn’t your engine you really don’t care that much if it’s messed up or not. Hence why everyone says rebuilds “let the Nissan magic out”.
The fact that your radiator is cold suggests you had a major cooling system failure. Within 5-10 minutes of driving it should’ve been too hot to touch with your bare hands. Coolant temp at the top of the radiator is going to be like 80C. Blocked thermostat or similar blockage in the system, water pump failure, etc can all cause these kinds of symptoms.
  • Thanks 1
@DuncanI think so too...but dont why suddenly i start to loose coolant...but i guess that it is how things go bad.
The smoke was only from the engine...no smoke from exhaust. And when i checked the oil it was fine(no milky just regular colored oil)
Yeah i will see this week what went wrong.
@GTSBoyYou think it could like "self destroy" after a year? The gasket was done like year ago and i drove the car couple of k km. But i dont know how these things "work" and if it can go bad like right away or just like this...
@joshuaho96I know but do not have a choice. Not many people here gonna work on that car/engine (as far as i know i am the only with this type of engine). Most of them(even that still no many) have GTT and have no time or they want like fortune just for a small things.
Yeah i start to think so too...i know i touch the radiator many times before to check and it was HOT to touch..no it was only little warm on left and in the middle where the cap is...completely cold.
The "block" thing should have been the problem..or the pump but it is/was new...done with the belts and everything around last year.
I will let you know but i think too that something happened with cooling system.
But thanks for the tips guys 🙂
Usually it happens again as the problem that caused it originally wasn't sorted properly, better off to put an import motor in than repair it.
The gauge won't show it's hot with no coolant because the temp sensor is dry, if you suspect it's losing coolant in the future try the heater on hot as they usually lose water out of the heater core early on so if doesn't blow hot it's losing water.
Happy new update(since last tuesday)
It was ONLY the broken hose from the heater core. Heater core was leaking so we took it out like month ago and just "connect" the hose until the new come out.
Being the 25 year old Japanese rubber...the hose do not like the new position and being "too" close to the exhaust(even with heat shield) and just broke.
So no HG no nothing.
My mechanic even told me(i did not know that) that Skylines have overheat protection when the engine starting to overheat they just cut the fuel...and that is what happened. Next day when the car was cold it started like new.
So at least something was not completely wrong 🙂
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
