Hey all im new here.
Just wondering if any ppl on these forums go to Swinburne Uni in Lilydale? or live around the area of Ringwood / Croydon / Kilsyth / Ferntree Gully.
Reply to this post with your car details and i'll keep a look out for ya at Swiny or around your area when im there next :)
Cheers
https://www.sau.com.au/forums/topic/48465-swinburne-lilydale/
sweet man!! come say hi
be good to meet more ppl!!
i only had my car for about 2-3 weeks
I seen a real tidy three two at swiny only once but. was on a day where the tafe had a free bbq. about 2 weeks ago maybe. Had white rims that where about 17inch and was an auto. Is that ur car AWDMAT?
what days do u go to swiny? i go MON, TUES, WEDS. i study Multimedia CERT IV in the tafe department. Drive a Mazda 323 Protege thats dark green.
Im Sean by the way :D
hope to see you all around
yeah thats mine man!!
i go tues, thurs and fridays
catch ya round sean
Hey dude what time do u go to swinny on a tues?
im there 9:30-4:00
if you go same hours we should meet at a certain time that suits us both in say the bottom carpark where no one ussually hangs out. that way we can have a chat and i can check out that monster of urs!! i think my lunch brake is 12:00-1:00 but i get heaps of '15 min' breaks as they call them. hahaha
hey man.
meet me at the bottom carpark at 12:10.
ill check this thread at 12:05 and if u havnt replied we'll do it another day.
soz it took so long for me to get back to you. this forum is having probs.
p.s. ill be wearing a white hat and brown top. cu there hopefully.
make sure u reply!!
Alright Swinburne....You wanted the best....You got the best...
Meet and Greet for anyone on this forum that goes to Swinburne. details as follows:
Date? Tuesday 24th AUGUST
Where? The first carpark on the left as you first come into Swinburne Lilydale. (gravel carpark)
Time? 12:30pm
Hey im not expecting much of a turnout, 3 at most im guessing. So i hope you guys can make it. Even if you can just come and say hi quickly that would be cool. Good on ya fellas. See you there! ;)
P.S. either reply to this post or send me a private message letting me know if you are coming
im up for a bit of a meet up cyco
let me know when and where
No worries, haven't got any cruises organised just yet, however I'll be going to the SAU-Vic meet / barbeque at Albert Park on 12/09/04
.:SAU-Vic Official Membership Take-on Meet:.
A few of us could meet up beforehand (around 11am, Eastland carpark maybe?) and convoy towards Albert Park from there.
I'll post a Melways map ref / route closer to the date, if you're interested
Guest Flawless
No worries' date=' haven't got any cruises organised just yet, however I'll be going to the SAU-Vic meet / barbeque at Albert Park on 12/09/04
That'd be cool!
:ghost:
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
    • But I think you missed mine.. there is also nothing about the 98 spec that supports your claim..  according to the fuel standards, it can be identical to 95, just very slightly higher octane number. But the ulp vs pulp fuel regulations go show 95 (or 98), is not just 91 with some additives. any claim of ‘refined by the better refineries’ or ‘higher quality fuel’ is just hearsay.  I have never seen anything to back up such claims other than ‘my mate used to work for a fuel station’, or ‘drove a fuel delivery truck’, or ‘my mechanic says’.. the actual energy densities do slightly vary between the 3 grades of fuel, but the difference is very minor. That said, I am very happy to be proven wrong if anyone has some hard evidence..
