Hey all im new here.
Just wondering if any ppl on these forums go to Swinburne Uni in Lilydale? or live around the area of Ringwood / Croydon / Kilsyth / Ferntree Gully.
Reply to this post with your car details and i'll keep a look out for ya at Swiny or around your area when im there next :)
Cheers
https://www.sau.com.au/forums/topic/48465-swinburne-lilydale/
sweet man!! come say hi
be good to meet more ppl!!
i only had my car for about 2-3 weeks
I seen a real tidy three two at swiny only once but. was on a day where the tafe had a free bbq. about 2 weeks ago maybe. Had white rims that where about 17inch and was an auto. Is that ur car AWDMAT?
what days do u go to swiny? i go MON, TUES, WEDS. i study Multimedia CERT IV in the tafe department. Drive a Mazda 323 Protege thats dark green.
Im Sean by the way :D
hope to see you all around
yeah thats mine man!!
i go tues, thurs and fridays
catch ya round sean
Hey dude what time do u go to swinny on a tues?
im there 9:30-4:00
if you go same hours we should meet at a certain time that suits us both in say the bottom carpark where no one ussually hangs out. that way we can have a chat and i can check out that monster of urs!! i think my lunch brake is 12:00-1:00 but i get heaps of '15 min' breaks as they call them. hahaha
hey man.
meet me at the bottom carpark at 12:10.
ill check this thread at 12:05 and if u havnt replied we'll do it another day.
soz it took so long for me to get back to you. this forum is having probs.
p.s. ill be wearing a white hat and brown top. cu there hopefully.
make sure u reply!!
Alright Swinburne....You wanted the best....You got the best...
Meet and Greet for anyone on this forum that goes to Swinburne. details as follows:
Date? Tuesday 24th AUGUST
Where? The first carpark on the left as you first come into Swinburne Lilydale. (gravel carpark)
Time? 12:30pm
Hey im not expecting much of a turnout, 3 at most im guessing. So i hope you guys can make it. Even if you can just come and say hi quickly that would be cool. Good on ya fellas. See you there! ;)
P.S. either reply to this post or send me a private message letting me know if you are coming
im up for a bit of a meet up cyco
let me know when and where
No worries, haven't got any cruises organised just yet, however I'll be going to the SAU-Vic meet / barbeque at Albert Park on 12/09/04
.:SAU-Vic Official Membership Take-on Meet:.
A few of us could meet up beforehand (around 11am, Eastland carpark maybe?) and convoy towards Albert Park from there.
I'll post a Melways map ref / route closer to the date, if you're interested
Guest Flawless
No worries' date=' haven't got any cruises organised just yet, however I'll be going to the SAU-Vic meet / barbeque at Albert Park on 12/09/04
That'd be cool!
:ghost:
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
