Looking at upgrading my brakes whilst my engine is being built
Is it really worth spending the $$ for a big brake kit on my 34?
or would a good set of DBA Slotted rotors (t3 4000) and pads suffice (dixcel type z or project mu F236 HC+)
Any other recommendations for rotors?
I mean going to 355 will look nice but is it worth the $$?
For reference will be buying work sp13 18s
https://www.sau.com.au/forums/topic/484651-r34-gtt-brake-upgrade/
DBA 4000 is fine, as are PMu HC+. I wouldn't bother with a BBK unless you're taking it to the track. That's really where these cars need the BBK, they're heavy and don't have enough thermal capacity from the factory unlike a modern sporty car.
17 minutes ago, GTSBoy said:
For street there is certainly no need for anything larger than the 310s on the R34. A few years ago you could preach a GTR upgrade to 324, when the calipers could be bought for reasonable coin. But not any more.
For a 34 which will be built for 500kw and maybe do a track day once a year BBK are over kill you would say?
Might even consider going project MU rotors over DBA if anyone knows if they're better than DBA
Do the dba t3 5000 324 directly bolt on to the gtt ?
It really depends on how you plan to use the car on track. Do you want to do 20 minutes sessions on R comp tyres on the track flat out the entire time? This will need plenty of cooling upgrades and the BBK will be 100% needed for this scenario.
Are you happy to do 2 or 3 laps flat out then let the car cool down before going flat out again? This scenario is much easier to achieve and could be handled on upgraded rotors/pads no problem.
  • Thanks 1
Any of the R chassis rotors will go on any of the other cars. The R34s used 14mm caliper bolts, so you have to make sure that your Vspec calipers suit that (ie not earlier ones), or be prepared to make suitable inserts for them.
But this would be senseless, because GTR Brembos cost nearly as much a proper BBK upgrade these days.
  • Thanks 1
Yeah i did some digging and figured so
Might just go upgraded rotors and pads for now and if I increase track work I'll look into going either BBK or go down the road of using alpha omega adaptors and go evo brakes
Thanks for the info
For reference, my race car (only has 300ish kw) does 20 min sessions, sprint races, enduro races 2hrs+, tarmac rallies up and down long hill runs etc etc on standard size GTR rotors (324mm). It does have slightly larger calipers and pads (porsche 4 spot) than factory but really it comes down to disc and pad selection.
  • Like 1
