Alright forum gods, i need your help again. RB26 just recently started making this very light tapping/knocking noise in the engine. It almost sounds like a bunch of marbles being tossed together. It just recently started happening or i might be going crazy because i didn't notice it before. It happens at idle, SOMETIMES. But it goes away the more i rev the engine. I'm not sure if i can't hear it because of my exhaust or if it actually goes away, but the sound DOSENT get louder the harder i drive it. In fact, the more gas i give it, it typically goes away but will occasionally come back.
I did some research and i think it could be the lifters, i dont know too much about them besides that they help the valve open and close. Any remedy to this? And i'm i still safe to drive with it in the mean time? The weather is great now.
Expand
If you're unaccustomed to engine internals and noises, you should cease driving it and seek a local mechanic. You only seem to be assuming it's lifters based on very little information. "Marbles" does not sound good.
Alright so at the same time this tapping sound is happening, i'm also chasing a misfire from those red coil packs. On my way home from the store just now, it started misfiring really bad. I drove straight home immediately. The car was shaking at the stop light but it eventually went away when i started driving it.
Could the tapping/knocking and the misfire be linked?
When i say misfire, it acts like it dosent want to go past 4000k RPM for a few seconds and it eventually breaks past it and will drive normally. This happens very sporadically but on 50% of my drives. Spark plugs are already changed.
Expand
I would start by making sure that it isn't rod knock or low oil pressure. Until you diagnose where the noise is coming from you aren't going to figure this out.
  On 06/05/2023 at 1:46 AM, r32-25t said:
Why are you still driving with those coil when you know they are faulty?
Expand
I felt bad just going maybe 50 yards with my cylinder 1 coilpack melting down, I have no idea how people are ok with doing this for miles and miles. The stock ECU is so basic it has no idea that something is wrong and to shut down fuel injection.
  On 06/05/2023 at 3:35 AM, kevboost7 said:
I dont know, im just ignorant. im not driving it anymore till i figure it out.
Expand
Well, at least there's some hope that the engine can still be salvaged if you didn't just drive on it until you windowed the block.
  On 06/05/2023 at 3:28 PM, kevboost7 said:
I'm not taking it to the mechanic.
Expand
That's where I'm at these days. Far too many cases where "good mechanics" have done something to my R33 so I no longer trust most people to work on it. As mentioned before none of us really know if your issue is rod knock or not. I just mention it because you want to eliminate the worst case possibilities first before spending time/effort/money/heartache on what I can only describe as copium/hopium fixes.
description doesn't sound like classic rod knock, that tends to get worse from idle to 2000.
does it only happen when you are driving/full throttle/medium revs and sound like rocks rattling in a tin? that would be pinging.
Maybe take a recording of the noise to give us a chance
Expand
I agree but someone local to me had rocks rattling in a tin as the symptoms and it went away with load/revs. Turns out he was wrong to ignore it and it wasn't just a bad input shaft bearing or something like that. It's surprising how idiosyncratic failures can be.
  • Like 1
Expand
You've got little mechanical knowledge, but an issue that could potentially cost you an engine you won't seek out a professionals help to at least start to diagnose?
Rattles like described can be a lot of things.
It could be lifters, it could be oil pressure issues, it could be a bearing noise, it could be a baffle in your exhaust.
Since you've also got issues on the coil packs, you may have other fatal issues that have now cropped up.
With the coil packs failing, did you ever have anyone or yourself adjust the position of the Cam Angle Sensor?
The car might be pinging off it's head down near idle (which could destroy your engine very quickly).
  • Like 2
  On 09/05/2023 at 5:51 AM, Dose Pipe Sutututu said:
*looks into crystal ball*
kevboost7: I'm wondering how much a basic rebuild will cost? Also should I replace those red coil packs at the same time?
Expand
*Shakes magic 8 ball*
"No, keep the red coil packs with the rebuilt motor..."
  • Haha 1
Expand
Expand
I hear that those yellow ones are better 馃ぃ馃ぃ馃ぃ
  • Haha 1
Expand
You should ask Trent at Chequered Tuning what he thinks of them lol.
  • Haha 2
    • Given you already have the engine cross member to match and likely gearbox mount to. The SR20 has a head start on the RB in this case. They handle GREAT with an SR20, lots of fun.   One I did back in the day
    • have no doubt and wanted too trust me and may regret later not necessarily worried about weight (would be 8 kg ish total) it was more the $$ to do it properly is about $6 - $7K in hardwear need long 310mm stroke jacks etc - plus install and call me whatever im not doing it myself even if wanted too cant weld etc  - thats $10K installed vs fraction of that cost while Ive spent some money on this POS I actually really dont like doing so unless its got a large chance to make me go faster 馃榿 hey in still carting this things around on a 15 yr old rusted open trailer so I can spend on racing not buy a new trailer to look better the manual jacks Ive had done are heavy and take space but are transportable and usable anywhere - taking or organizing even compressed air let alone nitrogen which is more whats needed coming from Perth to Winton or Sydney or the like honestly just adds to my brain headaches/ hurts of organisation also ha 15 mins job will get down to 2 - 5 min job vs 1 min job for airjacks - all tradeoffs I spose
    • Purely out of curiosity, how do you know all this @dbm7? Do you work with automatic gearboxes professionally? This goes way way way beyond "I've had an automatic Skyline once and did some mucking around"
    • I'll just reiterate that it's best to do all the wiring diagnostics, before even thinking about buying replacement solenoids ~ that is, be absolutely sure the solenoid is bad.....ie; bad connector(s), rodents chewed through a wire, etc etc. If you don't so this, you can fork out all the money for solenoids, only to find something else is wrong (this'll make you cry if you pull the valvebody only to find a broken wire is at fault... ...some more glue on the solenoid packs -- this is the RE5R01A shift solenoid assembly.... ...these are all shift solenoids ~ ostensibly they're the same as the shift solenoids from the 4-speed auto.... ...this is the RE4R01A solenoid set... ...with these, you have 3 shift solenoids attached to the plate, and the separate solenoid is the EPC solenoid (line pressure control) -- with both designs, the TC lockup clutch solenoid (also PWM so they could slide the clutch shut), is located on the lower valvebody half.... ...(story time)...back in the 90's, it was a common fault that the EPC solenoid (or TC-lock solenoid) would fail, but Nissan only sold them as part of the assembly (think ~$350 at the time) ~ thing was, Isuzu also used these boxes in light commercials, and you could buy the PWM solenoid as a separate part, so it was possible to buy/use that solenoid (around $65), and make it fit (remove the circlip, fit to old plate and deal with wiring)...making it a more cost effective repair. I've not seen the RE5R01A shift solenoid assembly, but with the 4-speed RE4R01A it was possible to hack/fit a single shift solenoid onto an other working set, using a donor solenoid from another set with failed EPC....(by rights the whole set should be replaced), but it ends up being a question of how much life is left in the box itself ; sometimes it's a viable repair to fix one solenoid, just to get another 100k of road miles out of it before it needs first overhaul...other times the box is that old/worn, you're as well doing first overhaul and replacing the solenoids and starting fresh... What Nissan did here with the 5-speed, was relocate the EPC solenoid to the lower valvebody (next to the TC lockup solenoid), and stuck the direct-drive clutch solenoid (for the extra gear) where the EPC solenoid used to be on the 4-speed....I can only imagine they did this for serviceability ; the PWM solenoids are most likely to fail, and it's a doddle to drop the pan and change these out (as opposed to dropping the valvebody itself to get at a top mounted EPC)... ...also keep in mind, that some BMW 3/5 series & Mazda (and maybe some Ford/Mazda rebadges, not sure), also used the RE5R01A box under a different name/part number...not saying parts availability is any better, but sometimes it helps to know this when it comes to NOS floating about in the EU.... HTH
    • FWIW, air jacks are actually pretty light and simple to add, they are just 4 hydraulic cylinders (often at the main cage A and C pillar points) and an externally accessible airline  - they make quick work a breeze
