Hi, was wondering if anyone can help with my issue would be much appreciated.
r34 gt4 4wd non turbo originally
installed stagea 2.5 turbo 4wd engine into r34
got it running just fine with some niggly issues
few questions
idles at 900rpm cold or hot, ideally when cold should idle high and then drop. It sits consistently no missfire or cut off. Power to idle control valve is present, tps set correctly, diagnostics code 55 no faults. No engine light also.
currently using stagea turbo ecu would that cause a conflict?
injector resistor, not installed is this important? Will it need to be installed?
4wd light is on also , front abs sensors need replacing as they broke and are not on vehicle hence abs light is also on.
Thank you in advance any support would really appreciate.
No. Better than GTT ECU which would have a shit fit about not seeing the TCS system. Besides which, it's the right ECU for the engine, yeah?
If it's all working electrically, then expect that the IACV is dirty and stuck so that it won't close enough to drop the idle.
What injector resistor? There is not supposed to be one.
Well.....
Step one would be to unplug the IACV and see how low the idle drops. If the bypass screw isn't closed enough, it won't matter how well the IACV is working.
I do agree with pulling IACV and cleaning it though, would do it either way. Really should have been done before engine install into car.
Hi there is power to idle control valve, issue is no cold start, it starts at 900rpm and will stay there.
changed idle control with another same issue
injector resistor is found on gtt models and stagea. Gt four non existent, with this car now turbo would it need this wiring in
OK, so the opposite problem of what I gathered (because I didn't read your OP properly). You see, 900 is high, so I presumed your problem was that it wasn't dropping down from 900 to the correct idle speed of 600-650.
So you actually have 2 problems.
The cold start on the Neo IACV is a wax pellet thermostat thingo that is heated by coolant. If you do not have coolant flow to it, then it simply won't close. So idle will stay high. The coolant path in these things can get plugged up. I had to extensively clean mine out after the engine swap to get it to flow coolant. Was full of red rusty deposits (as was the whole engine, which took ~5 coolant flushes to come clean). So....have a look.
Now, if the cold start valve is fully open, then that might explain the lack of dropping to proper idle speed. The ECU could be dialling the stepper back to minimum opening and not gaining control because the cold start is just too much for it.
yeah. nah.
Here's the top part of the R34 ECU and engine wiring diagram. The injectors are on the left. See the resistor? No. I can't either. High impedence injectors just don't have them.
This is the resistor found in engine bay that Iam askin about
Just to be clear, was that in your car or is it a sample pic?
Looks to me like an injector resistor pack
Either way, you need the wiring loom and engine to match, and it sounds like they do (plus, the engine is running OK). Therefore, I would not worry about anything that was in the car for the old engine setup
sorry guys dont know how to respond to comments on here thanks for the wiring diagram, im confused as i have r34 gtt here with fuel resistor so i assumed i would need it for this car also.
it seems to be working just fine just want to be on safe side. Just need to sort this cold start issue out need it to idle high and then come down once warm
I would like to point out that the RB26 injector resistor linked by OP is a rip off. US$165, but can get them here in Oz for AU$150 from Just Jap.
RB26 cars have injector resistors because they use low impedance injectors and the ECU actually wants to see high impedance. Nissan did some weird shit there to get the injectors to do the peak & hold stuff. There are actually 6 resistors in there. One for each injector, and that's why there are multiple wires in the lead and plug.
All other RBs use high impedance injectors. Therefore no resistor.
The resistor that you will see in the engine bay in other RB engined cars only has 2 wires. That one is the dropping resistor for the auto trans, as Ben said, and as shown in the manual on page AT-7.
  • Like 2
Hi alot of trouble shooting later, repaced the dump valve back to standard idles better no cutting off, still no cold start, changed iacv, coilpacks, theottle body, iat sensor, as inahve two sets of everything still no change.
now i may think it is ecu related as the ecu installed into r34 is  from a neo stage 4wd rb25det but it is auto my car is manual from factory.
Thanks for the reply guys dont know how to
reapons individually yet 🙈
attached is picture of ecu
3 hours ago, GTSBoy said:
Have you followed my other recommendation? Coolant flow?
Hi yes fully cleaned, will remove today again and clean, have noticed when setting idle learn when i connect the tps plug revs increase ever so slightly,
will be checking neutral switch to pin 39 on ecu to ensure this is wired
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
