Looks very nice  . . . however I have never see an impeller corrode out over time.
If you are using the correct coolant there should be minimal or no corrosion in the engine at all !
The bearings will probably wear out before the impeller has issues.
There might be an advantage if the pump is rebuildable as was done in dinosaur days of the past !
  • Like 2
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979167
If its going on an RB25/26 then you are better off getting the proper pump.  The RB30 one fits fine but has one less mounting bolt up near the top......and they always seem to leak in that area albeit after a few miles.  The proper RB 25/26 ones seem to hold tight longer IMO.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979329
I'll be install on a RB30 block.
Are you descriping the slotted hole?
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979332
3 minutes ago, Predator1 said:
When will yours be running? Keen to hear how your 9280 turns out.
It will be a ways away. I'm painting my car on top of waiting for parts all the time. I will definitely update when on the turbo when I get it running
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979723
2 hours ago, Predator1 said:
Nice man. Can I ask about your head? What mods etc? I hit a fkn brick wall on my setup, so keen to hear others running EFR on rb30's.
I got my head worked on by Mazworx out in Florida. I went with their stage 2.5 package. Cams are Kelford 182-SE.
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979761
Looks great !
I took a quick look at their web site and the price is up there in comparison to other quite well know brands.
But in saying that, that's a machined bronze impellers and certainly looks the goods.
Still got to ask if its re-buildable ?
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979770
56 minutes ago, PLYNX said:
Looks great !
Overall its different. I figured I'd give it a try. If it's sucks then, i can at least say is not worth it and suggest an N1 or Reimax.
I forgot to ask about if it's rebuildable. I can only assume it is.
The price is a little higher but with the impeller material and machining I can see why.
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979776
How much was that WP? Just out of curiosity, what are the flow rates? I recently changed mine because Im a overly pedantic fkwit :D and decided to splash out on the Gr.A Reimax waterpump.. and it made a pretty good dent in the coolant temps.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979791
I paid $327USD
I dont know the flow rate. I can imagine its high considering the length of the blades. Id have to measure the impeller and math it out
I saw your thread about the cooling issues with your intercooler and hypertune lol.
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979792
IMG_2691.thumb.jpeg.b150048c2cc0cf6fc750b28a56f8e400.jpegIMG_2696.thumb.jpeg.2985f022aa79940fb72f13702f59f03a.jpeg
Yeah! Hence why I was wondering. Looks like it should flow better then OEM/GMB style pumps. Its similar to the one I have.
haha dam right about Hyperf*knshitTune. Honestly stay away from them. I should have gone with Plazmaman instead. At least they were straight up and honest when I asked them specific details.
Mind if I ask what specs of your head? Feel free to pm if you want to keep it low key. Id be happy to share mine, just trying to compare setups and understand why the f**k my turbos out of puff.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979793
Yes in theory the larger impeller should flow more. from reading around, the vortex style impeller should be better than the open style
I have been dealing with them since last Sept for a radiator/fan combo. Stilll waiting...
Head:
CNC ported
Supertech Intake Valves, +1mm
Supertech Inconel Exhaust Valves, +1mm
Supertech Bronze Valve Guides
Supertech Dual Spring Kit, 92/82lbs
Supertech Titanium Retainers
Supertech Valve Seals
Kelford 182-SE
I chose the keep the quench pad as I havent read anything solid around to remove them for a street car. removing the quench adds about 70cc
Edited by SLVRBAKSLPZ
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979795
Head:
CNC ported
Kelford 182-SE
Why am I not surprised haha. Peter is such an absolute cock. False promises after another. I was on the verge of threatening him. My advice, steer clear of them at all costs. He LOVES to take money, and once youre paid up, communications just drop and you have to literally beg for updates, where you will get grumpy short replies.
Anyways, your head is similar to mine, what duration/lift? Im running 278/286 with around 10.8-11mm lift. Did they do a flow test pre/post porting? Mine flowed 300cfm post.. which is supposed to be quite a lot apparently.
  • Like 2
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979796
Yeah, Im not messing with them after this experience. I had to contact one of the fab guys on IG before pete sent me an "sorry we've been busy" email. The fab guy has been my POC for the last couple months. Now pending shipment.
274°-270°/280° | 10.55mm-10.50mm/10.50mm Valve Lift - 274°/270° split lobe intake, 280° exhaust. The head gets delivered today actually. I will see if it comes with e blueprint/flow sheet.
  • Like 1
https://www.sau.com.au/forums/topic/484657-water-pump/#findComment-7979824
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
