11 hours ago, admS15 said:
I've been driving modified shitbox Nissan's in Victoriastan for the last 9 years and have been pulled over exactly 0 times. Actually that's a Iie, I got pulled up once when I blasted past an undercover at 20 k over. Copped a speeding fine only which was surprising considering my wife was yelling abuse at them.
Honestly, you don't see many cops on the road anymore. Probably all working from home or just eating donuts back at the station.
Just don't drive like a dickhead in the wrong place and you'll be right.
gonna seem like a dunce.. but what does victoriastan stand for haha? but yeah nah, ive memorised most of the cop spots, even then, if im gonna speed ill do a pass by of the place first before going to make sure im not gonna get shafted haha
Dictatorship of VIC. Cops here have the reputation of being cunce to drivers of modified cars.
haha, love that. but yeah i have noticed that, had an 03 impreza, not a single engine mod done to it, only made it look nice, legit all rice... got pulled over and abused for pretty much no reason, tried to defect me on it being to low, it was just high enough. tried to say the body kit parts i had werent stock so therefore not allowed (first off.. wtf) but they were just sti parts so they couldnt do jack squat
51 minutes ago, GTSBoy said:
Well, there's your problem. Never been one of those on the road that didn't need to be pulled over for a random drug search or to inspect the treadless tyres.
haha, funnily enough, never touched drugs or vapes or smokes or anything like that, but i get what you mean, although the treadless tyres.. different story haha
  • 10 months later...
On 11/05/2023 at 2:57 PM, soviet_merlin said:
If you are set on the aeroflow intercooler I have one that was on my car. S2 Stagea with 260awkw.
It's sitting in a box in my garage and I'd be happy to pass it on. You would just have to pay for shipping from Sydney. Should have all the piping as well so may potentially be bolt-on. Or as good as. See attached for what it looked like on the car. Not sure if this is the right gear for entering beauty pageants but I think it'll look fine with different hose clamps.
Just bringing up an old post, but you wouldnt by anychance still have the intercooler would ya?
Yup, it's all still sitting in a box in my garage. Just message me on the forums and I'm sure we can work something out if you want it.
    • I mean, if you were to move the jacking points away from the original location, that is, away from the wheels and closer to the centreline of the car, then it will be more likely to overbalance and tip off the supports. Same as we talked about before. I was talking about moving for-aft. If the sill is bent outward or inward, then the car would obviously look unstraight from the outside. Hopefully that hasn't happened either. Again, you can do comparative measurements from the chassis rails to see if there is much deflection.
    • Can you elaborate what you mean with your first sentence? I meant move as in the bulge kinda seemed like it got pulled "outward" meaning it got pulled down and to the side with the jacking rail itself, so the load bearing bulge now sits lower than usual and is not level with the sill on the other side of the jack point. Either that or the jacking rail just got pushed in a good bit.
    • As well as being risky WRT tipping off anyway. Yeah, I wouldn't expect it to move. Just measure from the rear one to the front one on the good side, then measure that same length on the wrecked side. You will find the notches in the pinchweld, and the jacking pad. Just spray a spot of marker paint or something there.
    • but any other area than the bulge you are talking about will just cave in then? The front driver side is pretty bent so I don't know if that will work the way it is now. I can still kinda make out where that bulge is/was but it looks like the position of it also changed due to all the mistreatment? Hard to tell
    • Absolutely. Look very closely at the photo (of yours) that I took my second snip of. See how the sill is thicker material right behind the pinchweld, where the two notches are? That is the factory reinforced area for lifting. That pad is supposed to carry the weight. The factory jack (go look at it, and how it interfaces with the car at the pinchweld) shows you exactly how the load is carried from the car to the jack to the ground.
