19 minutes ago, JayJay777 said:
damn that insane
Just proves you don't need a fancy intake plenum.
Current iteration I'm running a FFP, kind of a "might as well" moment because needed to fit DBW and delete all the garbage idle control leak valves and other useless crap.
  • Like 1
the way im thinking about it is that if I get one now i wont have to get one later, another thing as well. to the dismay of someone else on this thread, i like the ffp because they look better, and because this is going to be a show car as well as hopefully a little beast, i wanna be able to open the bonnet and have it look nice and clean.
Assuming the ECU can control boost, all you need is a MAC valve, wiring and vacuum line plumbing.
For ECU, that's kind of like talking religion, politics or whether pineapple belongs on pizza. Anything except the standard, untuned ECU can work, in cost order
Nistune + z32 AFM + Boost controller
PowerFC + z32 AFM + Boost controller
Link, Haltech basic models, they can run MAP and control boost so you just need the MAC valve) + wide band o2
Then a whole world of pain up to Motec
Price range for the hardware approx $1k-$5k
  • Like 1
47 minutes ago, JayJay777 said:
now im confused, youve said in the first part that a top mount and ffp isnt necessary however in your second youre saying theyre for performance? which one is it?
They are not performance mods, unless you need the performance that they are suited to, which is in the order of double what you are asking for. In your context, they are 100% cosmetic, and actually carry a performance penalty, in the case of the FFP.
As far as I am concerned a show car does not have to have any actual performance. If its purpose is to look pretty with the bonnet up, it does not even have to run. If you want a good performance car, then the things that make it pretty with the bonnet up are not necessary and can be counterproductive.
You do you. But a highmount and an FFP are not even remotely required. I'd rather spend the money on brakes, suspension and tyres than bling to make the guys with shaved heads want to blow you.
  • Like 1
yeah i had a look at a link ecu.. the one i want is just shy of 3k... which is pretty insane considering ive only ever owned sh*tboxes haha. but yeah ive begun making a list and so far its gonna cost around... 6k, but thats missing out on a lot of the plumbing, tuning and electrical labour i cant quite do myself. also planning on adding a few extra like a crank/cam trigger kit, some adjustable cam gears and the crank shaft extender thing (ive blanked on what its called, pretty much extends the crank and adds more splines) althought i do save money because the engine has already had some good head studs installed as well as fixed the oiling issue, so hopefully no spun bearings for me.
Not really an option without buying another (R32) ECU, unless it's an S2 C34 (and hence Neo engine). Best avvoided iin favour of the other options. Disclaimer, I have Nistune, so it's not as if I don't think it's a good thing. Just not as appropriate here, probably.
  • Like 1
I run a link in my stagea too, it does a good job
And, welcome to the slippery slope.  If you want to stay in a budget, a highflow in the stock location, with stock intake and routing, nistune, injectors will get to to around that power at about 1/3 of the price.
well like i said, 350 is what i consider a reasonable ball park and if i can use these parts to make more then ill make sure theyre not just cosmetic at all.
The crank collar is an engine out job, is the engine currently in the bay?
What are your thoughts on aiming for around 450kw? It will still be quite responsive and the high mount turbo and all the other parts will then make sense. The funny thing is, what you are describing to build vs a 450kw setup will be very similar in price.
yeahhh ive found that one out haha.
currently that list is comprised of
front mount intercooler (aeroflow)
link ecu (G4x Xtremex)
gated manifold and screamer pipe (hypergear)
electronic boost gauge (gfb)
high flow mod for my current turbo (hypergear)
front facing plenum
so defintely missing a heap of stuff but thats just what i have so far.
with what i have do you think i should be aiming for more power? cause 350 is just my ballpark, but if i can gain more without rebuilding the engine i will.
yeah engine is currently in the bay, but if i have to take it out i will. in my mind, an engine out to increase the longevity of the engine is worth the time.
and im not sure if youre keeping up with GTS boy, but im not opposed to spending a fair bit on this car. i opened this forum with an idea of what i could do in mind and it seems what i want to do is overcompensating a bit haha, im not opposed to aiming for way more at all, 450kw is mad! just dont want to be one of those guys who wants to get 1000hp on his first go sort of thing, but it appears i have undershot it and i guess now i look like i have no clue. but if its a few k more for the 450kw then thats fine by me.
8 minutes ago, GTSBoy said:
Tell him the price son. Any number with 4 zeros is not going to be what he wants to hear. Having a 2 or a 3 as the first digit will be the end of it.
only if the 2 or the 3 is followed by 4 zeros themselves, im not looking to spend 20 to 30k but im more than happy to spend under that. not quite sure where you got the idea of me not wanting to spend money on but you need to take a chill pill champ
Are you happy to spend 20k on this build?
It sounds like you'll be doing the mechanical work yourself and paying for any wiring and tuning involved? Is that correct?
  • Like 1
Obviously it’s all your choice, so if you want to be able to lift the bonnet and see obvious performance parts, then go for it and spend the many moneys to look the part. Otherwise, there’s some real good advice here to do things properly utilising as many stock parts as possible (note the stock manifolds will always be better than cheap Chinese knock off ones).
I personally went a hypergear turbo in the stock turbo location and a Greddy front facing plenum for 300ish kw. I’m still spending thousands on fab work, so nothing is really cheap haha. Note than when using stock location items, you can generally get quality off the shelf kits for exhaust, intake and cooler piping, so minimal fab work will be required..
id prefer not to but i can, it would just be gradual over time.
yeah ill be doing all the mechanical work myself and i know a few auto electricians and tuners who can help me, definitely not for free but it wont cost an insane amount
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
