Hey everybody,
I was wondering if anyone can could please tell what the bolt specs are for RB26 Rocker Covers & Upper Timing Belt Cover as I'm looking at having custom titanium dress up bolts made, and I'm uncertain with the other posts I found online because of the conflicting answers, so I thought I'd just ask to be sure.
Thanks.
Sorry, that makes sense on re-reading, why would you want torque specs for a bolt of the wrong material?
It is a weird bolt
Cap head with Phillips drive
27mm total length
5mm at 7mm shank for the rubber bush to go through
20mm of M6 thread
2mm of narrower shaft, I guess that is to help with centring
  • Thanks 1
Thanks Duncan that's a huge help, very much appreciated.
I hate to be a pain since you've already been helpful, but would happen to know anything about the timing belt cover bolts?
The only thing I could find out about them was their total length (including the head), the 3 long ones are 62mm while the 2 short ones are 28mm.
https://www.efisolutions.com.au/timing-cover-bolt-rb-vg-long-r31-r32-r33-r34-wc34
https://www.efisolutions.com.au/timing-cover-bolt-rb26-short-r32-r33-r34-awc34#:~:text=Size%3A 28mm long including the head.
205-234.thumb.jpg.eb5586e61fc5fe3d2c13f0fc06e9fc61.jpgimages(55).thumb.jpeg.10e225cc5ed6891ad8b7c9f90d49b000.jpeg
That won't be so quick and easy; I have a bunch of those bolts sitting around but don't know how many of which. The front and rear, upper and lower timing cover bolts are all over the place
I will be pulling the ex-race car engine apart sometime and can confirm exact specs then....but sometime has already by 5 months wait....
Weird that they listed length including the head, bolt length is normally specified from the mounting surface/excluding the head
Here is the diagram at least for number and relative size. It's not complete though (strangely), there are at least 2 long bolts on the top front cover but only 1 is shown
This shows it a bit better
I'd guess 2 long bolts on top cover, 3 short on bottom cover + 2 short on top cover.
Kudos have kits of genuine bolts that might help identify number and length:
Lower timing case (3 of same): https://www.kudosmotorsports.com/catalog/lower-timing-case-fastener-suit-nissan-rb20de-rb20det-rb25de-rb25det-rb26dett-excluding-p-1388.html
upper timing case (2 long, 3 of  short) https://www.kudosmotorsports.com/catalog/upper-timing-case-fastener-suit-nissan-skyline-rb26dett-p-1387.html
Upper backing plate, these look easy but note 1 x 1 size and 3x a smaller size: https://www.kudosmotorsports.com/catalog/upper-timing-case-backing-plate-fastener-suit-nissan-skyline-rb26dett-p-1389.html
  • Thanks 1
Ah f**k it, it is a lovely starry night and 100m to the shed isn't that bad while it is still over 10o
Both long and short bolt have 8mm of M6 thread and an 8mm shaft.
Short bolt has 22mm under the head
Long bolt has 55mm under the head
The cap head is 6mm high but I don't think that matters
  • Thanks 1
I'm sorry to have made you go to all that trouble, thank you again for going out of your way to help. I can't express my gratitude enough.
On 17/05/2023 at 10:47 AM, Ben C34 said:
Be sure to send Duncan a cut of the profits when you start selling them.
I have no intention to sell them. I've been going back and forth with a business that makes custom titanium hardware kits on request because I want my bolts to be anodised to a specific 50/50 colour scheme, however they've haven't yet made a kit for an RB26 before and told me I'd have to first provide them with the hardware sizing and quantities before they can give me a quote.
  • Like 1
  • Thanks 1
    • For me at least the reason why it bothers me is because it's indicative of a deeper problem. And that will nag at me forever. Especially because I have tailpipe emissions testing + evap leak testing every 2 years.
    • WELP. I went to the track, and I suppose it went okay because any time you can drive home is okay. You may notice the car is not on the circuit in this picture. It was about 35C day out in Benalla which means the track was approximately the surface of the sun, probably. Good things, car did not overheat but it _was_ warmer than when I had done track days in similar heat before, I think, I'm not sure - I can't quite remember. Coolant got to ~105 via the ECU after 20-30 minutes of belting it in said heat. Oil got up to 145C in one instance which is pretty crazy due to oil cooler. Pressures were fine. I seem to remember this not getting quite so high before the vents. More HMMMM'ing to be done. On the subject of HMMM'ing, can anyone identify the sounds in the video below, you will know which ones I mean: https://www.youtube.com/watch?v=uj3BkI2cbTc I included some 'normal' sound as a reference for the first minute or so. The microphone in this instance was where the license plate is. It stopped working later in the day which is why my "best example of a lap video (not produced)" had internal audio - Isn't hearable from inside the car. I don't mean the chirping of the un-bedded/badly bedded track brakes which you can only hear while braking... Thoughts, brains trust?
    • blame old mate Hawkins for that one  I remember way back in the day the japanese didn't want them either... they always assumed a race shell would be thrashed. We found a few when looking for an R34 GTR for the Whites to drive in Targa Tas back in 2002.
    • I know it's probably not going to cause any major engine issues. I just had a more generic concern that it's technically not running right (I guess this means the rpm is not sitting where it technically should be) Though the other thing is, it's that my steering wheel is shaking at 1,100 rpm at idle until it gets warm (seemed to happen after I tightened my alternator belt, will be testing the alternator soon).
    • I mean, what's the concern here? Higher fuel consumption? FWIW my idle sits at around 800rpm or so as well. And yes, it runs fine, idles fine and there are no issues as far as I can tell. I don't quite see the problem.
