  On 18/05/2023 at 6:21 AM, sonicii said:
https://nissan.epc-data.com/skyline/pv35/6830-vq35de/engine/130/
https://nissan.epc-data.com/skyline/v35/6815-vq25dd/engine/130/
As far as I can see the guides are the same part numbers for similar years too.
Expand
Thanks appreciate it can you help me find intake valve timing control bank 1 couldn't find it on the link
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979595
it looks like the valve/solenoid is built into the cover on the DD -
https://nissan.epc-data.com/skyline/v35/6815-vq25dd/engine/130/13040S/
Compared to the separate valve on the VQ35DE
Edited by sonicii
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979625
Expand
Thanks alot man I appreciate that I see it's like 800 plus dollars i think I've found the circle magnet that's in there so far it's a vvt magnet clutch but also I see the intake valve and exhaust valve on the schematic diagram I just dont know where they go it's on vq25dd diagram look to the bottom right corner and look for the matching numbers it says valve,intake and valve,exhaust I just wanna know what those are
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979630
The are the actual intake and exhaust valves, each cylinder will have 2 of each of them, these are not the variable valve timing solenoids, they are the actual valves.
You should be able to find plenty of youtube videos about how an engine works that will describe them well, every 4stroke engine has them, and most cars engines these days have 4 valves per cylinder (2 intake and 2 exhaust) but some have 2 (1 of each)
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979662
Ohhhhh ok thanks I appreciate the help much love and respect can I clean them or do I have to replace it
Expand
because 850 is alot for that part
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979672
Expand
The 25dd & 35de have a different vct setup, 35 rev up has the same as 25dd
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979695
  • 3 months later...
Expand
Does anyone know how to test the solenoid using the prongs and a multimeter I saw something some time ago cant fing it no longer the one that's built in on vq25dd engine any help would greatly appreciated
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7982916
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
