3 hours ago, sonicii said:
https://nissan.epc-data.com/skyline/pv35/6830-vq35de/engine/130/
https://nissan.epc-data.com/skyline/v35/6815-vq25dd/engine/130/
As far as I can see the guides are the same part numbers for similar years too.
Thanks appreciate it can you help me find intake valve timing control bank 1 couldn't find it on the link
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979595
it looks like the valve/solenoid is built into the cover on the DD -
https://nissan.epc-data.com/skyline/v35/6815-vq25dd/engine/130/13040S/
Compared to the separate valve on the VQ35DE
Edited by sonicii
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979625
Thanks alot man I appreciate that I see it's like 800 plus dollars i think I've found the circle magnet that's in there so far it's a vvt magnet clutch but also I see the intake valve and exhaust valve on the schematic diagram I just dont know where they go it's on vq25dd diagram look to the bottom right corner and look for the matching numbers it says valve,intake and valve,exhaust I just wanna know what those are
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979630
The are the actual intake and exhaust valves, each cylinder will have 2 of each of them, these are not the variable valve timing solenoids, they are the actual valves.
You should be able to find plenty of youtube videos about how an engine works that will describe them well, every 4stroke engine has them, and most cars engines these days have 4 valves per cylinder (2 intake and 2 exhaust) but some have 2 (1 of each)
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979662
Ohhhhh ok thanks I appreciate the help much love and respect can I clean them or do I have to replace it
because 850 is alot for that part
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979672
The 25dd & 35de have a different vct setup, 35 rev up has the same as 25dd
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7979695
  • 3 months later...
Does anyone know how to test the solenoid using the prongs and a multimeter I saw something some time ago cant fing it no longer the one that's built in on vq25dd engine any help would greatly appreciated
https://www.sau.com.au/forums/topic/484668-timing-chain/#findComment-7982916
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
