just wondering if anyone else has a knocking sound on there car while it idles. i'm looking at buying a car that does...apparently had it for past 10,000km drives really well. i've read past posts and people say it goes away when u press the clutch but i havent tried this as i dind't think of that when i checked it out. it's like a rhythmic knocking sound. it got checked by RACV comprehensive check and they said they couldn't tell me wat it was without removing the whole thing and they weren't aloud to do that coz i don't own the car. any help on wat it could be and how expensive it wud be to fix would be great. thanks
https://www.sau.com.au/forums/topic/48467-knocking-sound-on-idle/
I had a smillar noise on idle which came from the timing case. Took it some where and was told it was probably the belt. It did in fact work out to be the belt (timing belt) which was loose causing it to knock on the cover. They replaced the belt and tensioner and cost $500. Nearly asked for an ambulance mind you. F---in rip off.
wat gets me is that the RACV comprehensive mechanic check couldn't tell me wat it was...without taking removing belt/s to locate. they said it was coming from the drive belt area...is that the same as u???
probably but the report says something bout having to "remove belt/s to locate"...u think he means that it could be that...probably some stupid old man mechanic who doesn't know wat a skyline is...i'm jsut really worried i'm gonna buy this thing with ll my money and end up having to shell out another $1,000 to fix it. how much should i pay for a timingblet change in Melb. the clock says 85,000kms so maybe/most likely wound back and is due for timingblet change as it hasn't been done and the cars been here for 2 years...so
I was worried about buying my car too at the time so i took my mate who is a mechanic. He could only see the basics ie wierd noises, panel damage etc. Good idea to try and get somebody who actually knows about skylines because my friend didn't see a couple of things. EG the aircon belt was missing ended up costing 1000 for complete new system. And the timing belt soon after. Car had 60000km on it when i bought it but somehow dont believe it. As i said you did the right thing by getting an RACV check but if you know someone who knows about skylines get them to check it out.
As for timing belt cost. The belt $100 The tensioner $90-100. And about 3 to 4 hours labour max. So anywhere from 50-70 roughly per hour. I would have gone somewhere else but the work shop just took it upon themselves to do the work then tell me it was ready. Oh yeah was told the timing belt is the same as a VL. But double check.
thanks so much for ur help... is there any way i can check if it's gonna be the timing belt. like a test or something. i think everything else on the car is alright...cept for a few minor problems...water gettin into the boot...panels got repaired except they didn't replace the rubber properly. basically just little things afta that. i'll see how it goes.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
