I'm going to be buying a JDM from Japan soon and found a potential importer but I noticed on a lot of these JDM cars on the intake manifold and differential there is salt oxidation, which I understand cars over seem to be more prone to rusting than here. Is salt oxidation something to worry about if it's on the frame of the vehicle or is just general rust I should look out for?
Also I heard in Japan they don't have something like we do have here for PPSR or Carfax from America, but a guy told me they do they do have it, what's the best website to do the check if it exists?
CarVX is the nearest equivalent to Carfax in the US. White rust on aluminum parts like an intake manifold usually also means there is rust elsewhere on the chassis.
  • Like 1
Thanks man, I'll use that. This is the oxidation I was mentioning, is that technically rust? Seems like there is some yellow bubbling to.
The pic isn't great, but I think it is the exhaust heat shield with surface rust. That is perfectly normal, it is not painted because it is too close to the exhaust for paint to survive
  • Like 1
it's not technically rust, but it will deteriorate the shield over time. the chloride pits the metal over time. if it gets too manky you can just replace it. you can't paint it cos it gets too hot.
  • Like 1
Oh I was referring to the white metal thing at the back looks like the differential.
I meant this part not the exhaust shield.
Yes, so that's definitely the diff cover and they will all inevitably have white oxidation on them after a few years. There can be no expectation of raw cast alloy retaining any sort of nice as cast finish on an exposed part anywhere on a car.
The question is ....is it just the usual light coating of white oxide, or is it horribly consumed and covered in little encrustations of chlorides? If the former, then the oxidation state of the alloy parts is not really any guide to how rusty the steel parts might be. But if it is horribly messed up, then the car might have spent a lot of time driving through wet slushy snow and salt, and it might have corrosion issues. The only way to know if to have a decent look.
R33s and 34s in particular have a lot of problems around the front suspension towers. R32s less so there, but they can all suffer all over the place from salt. They should have all been rescued from Japan within 5 years of being built. Anything coming out of Japan now would want to have been stored in a garage or warehouse for the last 15 years.
  • Like 1
Ah ok makes sense, will cost be a fair bit to inspect so hopefully turns out right.
Yeah the oxidation is usually a result of a car driving through and sitting in salted roads. Which is common in Japanese high country. Super high chance if the chlorine oxide has formed that the iron/steel parts are rotted too. Get a thorough underbody check done and look out for tell tale cover up spray paint too.
Makes sense. Yeah will defs get a check, seems to be priced quite a bit less compared to others.
  • Like 1
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
