Hello everyone,
I am working on a 1993 R32 GTR for a friend of mine and have to install a Greddy oil filter relocation kit and a Greddy Oil Cooler. The oil filter relocation kit comes with two plates (one that goes where the original oil filter went on the block and one where the oil filter will eventually sit [somewhere near the dirver's side strut mount]). The oil cooler comes with a thermostatic sandwich plate which also seems to go where the original oil filter position was. However, it also mounts up to the plate from the filter relocation kit.
Do I just hook up both kits as normal and simply screw in the thermostatic plate on the oil filter relocation plate and then the oil filter on top of that? Or do I put the thermostatic sandwich plate on the block (and attach the oil relocation plate on top)
I have included a picture of the 3 plates in question. The plate on the left is the plate where the oil filter will go after being relocated, the middle on is the thermostatic plate that came with the oil cooler, and the plate on the right is the plate that screws into the block where the original oil filter location is. The second picture is just me test installing it to show my idea.
I was wondering how I should route this and needed input from anyone who has done this. I.e. How to arrange the plates and which tubes to go to which ports.
P.S. I didnt order these parts or plan this out I'm just the one installing them.
Thanks in advance!
You need to make sure the oil is filtered, whether or not the thermostat is opened. Can't really tell how it works from those pics and I assume there were no instructions provided....
Did the kit come with lines, or are you making them. The old school location of upside down on the strut tower is a crap idea. Much better to mount the filter upside down on the chassis rail in front of the front diff
Yes I'm sure its genuine. I believe the mistake my friend made was ordering a relocation kit separate from the oil cooler kit rather than getting the combined kit. I saw on Greddy's website these are 2 separate kits.
The kits came with lines. 2 lines on the relocation and 2 kits on the oil cooler.
Looking at this now I believe that the oil will be filtered whether or not the thermostat is open.
The first picture shows how the plate operates when cold. Oil comes up from the bottom and goes into the filter- and exits the filter back to the block. (when cold it comes through where the spring is in the hole).
The second picture shows how it will work when it is hot. The thermostat opens and the oil flows out of the thermostat plate to the cooler- it then comes back to the filter by the space that is now opened because the thermostat is open (and returns to the block). [Where the brass piece is now- as its at room temp its closed].
The third picture is the bottom of the thermostatic plate.
In other words, when the thermostat opens the part of the plate that would lead directly to the filter is closed but there is enough space left open for the oil to go directly to the cooler. Additionally the space that is now open because the thermostat is open allows oil to flow back from the cooler into the filter (through the left port).
The truth is they should have gotten the combined kit but probably did not realize they can achieve the relocation and oil cooler with one kit rather than 2.
What do you think?
P.S. The oil filter will go near the strut but it won't be upside down- it will be vertical.
Edited by Tom24GR
Adding the P.S.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
