14 minutes ago, bcozican said:
Koyo still decent do most jobs - $700
Recently wen PWR crossflow circa $1100 found big difference in cooling
big difference? at the moment sparesbox have 42mm or 52mm PWR for $850.
WHich did you go?
15 minutes ago, Dose Pipe Sutututu said:
PWR if you're rich, superb coolers OR Koyo, just works.
I would avoid that brand that's big in America and looks like rebranded eBay radiators with flashy marketing.
who might that be??
Edited by Adz2332
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979864
35 minutes ago, bcozican said:
https://shop.pwr.com.au/55mm-2-pass-crossflow-radiator-nissan-skyline-r32
55mm Crossflow is what I got went from 42mm (i think) typical koyo
koyo was fine but started to struggle on my setup as I pushed it harder - above cooler change has done the job well since no probs
\https://www.sparesbox.com.au/part/pwr-radiator-55mm-suits-spal-16-fan-x-flow-fits-skyline-r33-gtr-gts-t-pwr5652sp
same one! ill grab it thanks for the info!
  • Like 1
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979870
I've got a cross flow in mine from Race Radiators, it's a twin pass 55mm core. It was a fair bit more than a PWR but has a swirl pot and a few other things I wanted which you can't get off the shelf.
He's the Victorian agent for PWR and does their warranty stuff, he doesn't use their cores.
  • Like 2
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979872
Nice. Thats what I was going to get but at the time he couldnt get cores and said didnt know when he vould get me one
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979875
No idea if lever is better or worse, I've only every used the push down screw cap ones.
I run 1.3 bar cap on the race car and have got >130o coolant without blowing anything, not really recommended as best practice. Of course if you go higher pressure cap it is worth changing all water hoses to silicone and good hose clamps instead of the factory clips
  • Like 1
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979963
(personal opinion) I prefer to run a 1.0 to 1.1 bar radiator cap, FWIW with my 1st motor (stock), I had a 1.1bar radiator cap using an off the shelf 42mm PWR radiator and the car was thrashed and cooled down for a good 10 laps on a near 40 degree day at Wakefield Park.
Water temp never went past 120 C (from memory) and no coolant was gurgling, albeit it did have a 25 row Setrab oil cooler. I even used the A/C on cool down laps lol.
  • Like 1
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979965
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
