14 minutes ago, bcozican said:
Koyo still decent do most jobs - $700
Recently wen PWR crossflow circa $1100 found big difference in cooling
big difference? at the moment sparesbox have 42mm or 52mm PWR for $850.
WHich did you go?
15 minutes ago, Dose Pipe Sutututu said:
PWR if you're rich, superb coolers OR Koyo, just works.
I would avoid that brand that's big in America and looks like rebranded eBay radiators with flashy marketing.
who might that be??
Edited by Adz2332
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979864
35 minutes ago, bcozican said:
https://shop.pwr.com.au/55mm-2-pass-crossflow-radiator-nissan-skyline-r32
55mm Crossflow is what I got went from 42mm (i think) typical koyo
koyo was fine but started to struggle on my setup as I pushed it harder - above cooler change has done the job well since no probs
\https://www.sparesbox.com.au/part/pwr-radiator-55mm-suits-spal-16-fan-x-flow-fits-skyline-r33-gtr-gts-t-pwr5652sp
same one! ill grab it thanks for the info!
  • Like 1
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979870
I've got a cross flow in mine from Race Radiators, it's a twin pass 55mm core. It was a fair bit more than a PWR but has a swirl pot and a few other things I wanted which you can't get off the shelf.
He's the Victorian agent for PWR and does their warranty stuff, he doesn't use their cores.
  • Like 2
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979872
Nice. Thats what I was going to get but at the time he couldnt get cores and said didnt know when he vould get me one
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979875
No idea if lever is better or worse, I've only every used the push down screw cap ones.
I run 1.3 bar cap on the race car and have got >130o coolant without blowing anything, not really recommended as best practice. Of course if you go higher pressure cap it is worth changing all water hoses to silicone and good hose clamps instead of the factory clips
  • Like 1
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979963
(personal opinion) I prefer to run a 1.0 to 1.1 bar radiator cap, FWIW with my 1st motor (stock), I had a 1.1bar radiator cap using an off the shelf 42mm PWR radiator and the car was thrashed and cooled down for a good 10 laps on a near 40 degree day at Wakefield Park.
Water temp never went past 120 C (from memory) and no coolant was gurgling, albeit it did have a 25 row Setrab oil cooler. I even used the A/C on cool down laps lol.
  • Like 1
https://www.sau.com.au/forums/topic/484704-radiators/#findComment-7979965
    • These are small points I should actually add to my original post. GKtech makes an extended slave line for this conversion. It's what I use, and it works well. You'll also need a CD009 slave cylinder.  S/R Chassis Z33/Z34 Conversion braided clutch line As for transmission sensors, you'll need to both extend the wiring and replace the connectors. I can't recall which is which, but one is your neutral switch and the other the reverse switch. As they are just switches, just test for continuity with your transmission in neutral or reverse to figure out which is which. Connectors:  VQ35 neutral Switch Connector | Wiring Specialties VQ35 Reverse Switch Connector | Wiring Specialties
    • I’ll try and see it could be the release bearing. As for the 4th gear grind maybe clutch doesn’t disengage properly cause it is slightly like very slightly hard to go into first could be due to the slab cylinder pin being short uni clutch is a twin plate.   Ive attached some assembly photos hopefully you can open the link and see maybe detect what’s wrong https://share.icloud.com/photos/0dc2YvW__Hl6jl-l2_0jejjpg https://share.icloud.com/photos/09e0jkWOK-vP48c1cfY6u3ViA https://share.icloud.com/photos/0b4rDmh5R7pK7fb1VtND73a3g https://share.icloud.com/photos/05eeUi_6dC4DVi80jOUYDgb0g https://share.icloud.com/photos/06335TgY1XxyIJal_wkdQLhzw
    • Yeah for sure that is peddle adjustment
    • What are your thoughts on this after having it for a while, worth getting?
    • Downshifts are harder on transmissions than upshifts, the input shaft naturally slows down once disconnected from the engine so the synchros aren't doing all the work. There's no "natural" tendency for an input shaft to increase RPM. Something is not right there, I don't have a great answer on what. You can try a dedicated GL4 75W90, I plan to switch to Motorcraft XT-M5-QS which is supposedly a very good 75W90 for NB Miatas which have a weirdly sensitive transmission from the factory. I would chase down why your clutch is making a hissing noise, that's not normal. It might be no big deal but in the absence of anything else to investigate I would look at that.
