Hey guys newbie here. I've got a m35 with a VQ25DET and it has developed a bit of a ticking noise. I have heard that its pretty common for the timing chain guides to brake and wear causing some noise. I have unplugged the VCT gears with the motor running as I've heard that if they are the culprit it will stop with no luck so I am going to start by replacing the guides and tensioners though it sounds more like valve ticking to me. If it is the valves where would I start? There's so many different sizes in the valves listed, is it a case of just pulling them out and ordering the ones that match I would really like to avoid having to do that as it is currently my only car. Any help would be appreciated as the ticking is driving me nuts. Also when I cold start the car I get a horrible noise for a few seconds then quickly stops, could this be related or is that more to do with oil pressure and viscosity?
https://www.sau.com.au/forums/topic/484705-vq25det-ticking/
VQs use solid lifters. The clearance is set with a shim**. You first need to pull the cam covers off and measure all the clearances at running temperature with feeler gauges. You then dismantle the cams off the heads and pull the shims out and measure with a micrometer. You then order new shims at the required size to obtain the correct valve clearance for any valve that had incorrect clearance. If the clearance was too large, then the new shim will need to be thicker than the old shim by the difference between the required and actual clearances.
This is not something that you can just order the parts off the net and do in an afternoon. The car will be in pieces for at least several days.
**It might be the case that the VQs don't even have a shim and they just use graded bucket (with different thickness tops on them). In which case, in the discussion above, just replace "shim" with "bucket".
https://www.sau.com.au/forums/topic/484705-vq25det-ticking/#findComment-7979895
Yeah sweet thanks for that mate first car ive owned with solid lifters so i have 0 idea. from the catalogue they are a separate shim that sits on top. Under the listing I have multiple size options for both the lifter itself and the shims, if i was to replace them lifters would that be a case of ordering the same size or use that to reduce the thickness of the shims in there or just get the same size and buy shims to suit
https://www.sau.com.au/forums/topic/484705-vq25det-ticking/#findComment-7979896
I have no idea. There might be upper and/or lower limits to shim thickness which mean that if you need to go too far you have to get a different bucket also. Stay within the limits and keep the same bucket. That sort of thing. You'll soon work it out once measured up. Of course, once you can't know in advance until you have measured. You really need to speak to someone who has done this on a VQ to find out what the rules/limits might be.
https://www.sau.com.au/forums/topic/484705-vq25det-ticking/#findComment-7979897
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
