5 minutes ago, OO Dan OO said:
Just recently my accessories is staying on once my key has been removed.
is there anything I can test or a work-around to put acc on a seperate switch instead?
You sure your accessory relays aren't sticking closed? They hang out under the the interior fuse panel.
  • Like 1
I pulled all the relays out from under the dash. And accessories where still on.
I happened when I was re-fitting the cluster surround. I still had my keys in the ignition and had to kind of force them out.
do you know what relay in particular? Pulling it out should turn everything off right?
Top two relays are accessory relays, bottom-most is the ignition relay. That last bit makes me wonder if your ignition barrel is damaged as robbo mentioned.
I always love the way the story comes out in dribs and drabs.
OP, you f**ked it. It is up to you to work out what you f**ked. Luckily for you, Robbo is likely right on it.
Unluckily for you, these things don't grow on trees any more.
Edited by GTSBoy
  • Like 1
There is a connector to unplug the ignition switch from the wiring harness about 4 inches away. Unplug it and see if you still have acc powered on, if you do its the relay thats broken. Otherwise its the switch.
On the bottom of the ignition barrel is a tiny screw, undo that and the switch with the wires attached comes apart from the barrel.
When you have it out of the car you test the electrical switch itself.
  • Thanks 1
They don't sell the lock barrels anymore, but they do still sell the barrel switch and wiring which is more then likely what you need. Part# 48750-D4500. 30$
If for whatever reason you need the whole kit, 3gspares.co.nz has a used set.
I unplugged the ignition wiring from the harness and I still have acc on. Which relay should I check?
4 hours ago, alexj said:
you could look them up on the wiring diagram but its easier to just unplug the blue relays until the circuit you are interested loses power.
I have pulled every relay in the car out and acc still stays on. I even pulled them leaving all of them out and still acc is on.
thos is some kind of supernatural shit
Not supernatural, someone has probably messed with the wiring and it has effectively made the acc line always live. I have seen improper radio grounding do something similar before.
Turns out the acc do turn off but it was the dash and tail lights that won't turn off. I unplugged the headlight switch and they still stay on. At least I have ruled the switch out. For now I am powering the tail lights from a different fuse which turns off when the key is off. But it's a really hacky way to not have to disconnect the battery every time I get out of the car.
  • Like 1
That circuit is always live, just switched through the dashboard. So you'd have to figure out why the circuit is completing when it shouldn't.
Do you think it could have something to do with the high beam dash light? I think I may have removed it cos my beams don't work anyway
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
