Best Brake Upgrade for Looks
Hi all,
I hope this isn't frowned upon, but I am looking at upgrading brakes on my S15 mainly for the looks. I will obviously take whatever performance gains come with the upgrade as a bonus.
What I think looks good is large diameter rotors (around 350mm front and at least 330mm rear) and large calipers.
What do people think are the best option out there value for money wise?
Options I'm currently considering:
  • Attkd from Just Jap - Will cost about $5700 for everything
  • Evo Brembo's - Will cost maybe around $4500 depending on the caliper cost and condition
Others options are Akebono's with the kit from Concept Z Performance in the USA or CTS-V calipers (don't know much about this option and not sure if there is a kit for the rears).
14 minutes ago, GTSBoy said:
Full brake delete. You'll get many more admiring looks from doing that than any other upgrade.
Hi. Thanks for the helpful comment! Not sure if I should bother...... but:
  1. I'm doing it because I like the look, not to impress anyone else.
  2. Wouldn't a brake delete be the opposite of what I'm after? Maybe try harder?
23 minutes ago, waggat said:
Hi all,
Yeah I don't recommend doing this unless you need more thermal capacity. If your heart is set on doing this anyways I don't recommend random unknown brands for this stuff. Akebono or Brembo is fine though. Alpha Omega racing seems to like the Falcon FPV Brembos or Evo Brembos as you already mentioned. The fact that they're thinking about issues like pad knockback, suspension knuckle rigidity, brake bias, dust shield/piston dust boot retention, etc... is a good sign IMO.
I understand that by looks you just mean larger and new looking, so just grab whatever you can find cheapest in 350mm, any half credible brand will be adequate stopping wise. If you go the evo brembos you probably have to consider the cost of having them stripped, powder coated, rebuilt, re-stickered.
Personally I'd stay away from any home made kits as you won't know the quality of the caliper adapters which could be dangerous
  • Thanks 1
R35 GTR brakes with carbon ceramic rotors look the best for sure.
https://www.alphaomegaracing.com/product/r35-gt-r-brembo-adapters/
https://www.amsperformance.com/product/alpha-performance-r35-gt-r-carbon-ceramic-brake-package/
Some say you can't put a price on looks. Others say that you can and it's about $35,000. But think of the value because really, the looks are priceless.
  • Like 2
Saw someone on FB Marketplace post full kits for ~10k. Not sure if I consider that the best value for money compared to the Attkd kits for $5700.
Sounds like they were just selling their R35 brakes. The big bucks are in the carbon ceramic rotors, those are about $20,000.
When you're going for max looks, gotta have those carbon ceramic brakes. I don't see Attkd selling a carbon ceramic option, so do you really have any other choice then the R35 kit at this point?
Meh.... Another comedian!!
  • Like 2
Best value...........
https://www.ebay.com.au/itm/165900019651?hash=item26a06967c3:g:6qEAAOSwSOdjqVhv&amdata=enc%3AAQAIAAAA8C%2BdCsusVox3XxUhK3ZiFvts0Iy55uejoqdGDtbN3KFBlyCJ0Iw4j7sYBjppoq5%2B75RTWHeDLJoGT76cJNyYGgmiwFrHXMJ4M%2Fn4vkA8VO90YnBfBql2IhQnc5wmbNXQrnwFpLm6FLuSsbFC6BnXaSa%2FwVbXEB8hmMs9jk52ycwVMNQ5L%2Fxlc1q0UhKZuAhTalsCpmXv9aCGYDc2UCgnZ8FalU9wP%2FC%2F5Ut4YNQGTxnxahXiQgDixf5U73w8pWGNLnx0t2UJWtrC%2BDJfR7KTivVsocucxrdOwioWSO%2FcHhtSDLqhm6eIPFLDF0Q5VcsccQ%3D%3D|tkp%3ABFBMvOePnY1i
I have a EVO brembo setup and its around $6k with quality rotors, pads and refurb. Will only fit behind certain 17s so recommend 18 inch wheel with big brake clearance faces.
Any brake setup will also require a BMC upgrade, possible new lines, may have ABS issues and a possible hand/park brake relocation.
  • Like 1
Hey mate, thanks for the response. Yeah I'm aware of most of those potential issues.
Is there any downside to running bigger brakes when done right? Or is it that people cut corners when it's just for looks and it compromises on a major safety component?
Genuine question as I'm not sure where the hate comes from. Big brakes certainly look amazing.
This is true. And then you've spent $3k or $5k or $10k or $35k (if you've done it the best way) and you have something that looks good but doesn't actually do anything useful.
I'd rather spend $10k on the suspension. Black arms of course, because I give no f**ks for the looks.
I wonder what wheels you've got...... I assume steelies in your desired diameter, width and offset.... f**k looks hey!!!!
No, of course not. Now you are really showing that you don't know what I'm on about. Steel wheels are heavier than the very light RPF1s that I have. Why do I have RPF1s? Because they are very light. Are they the best looking wheel? Hell no. Are they close to the optimum of light & affordable & not ugly. Yes. Yes they are.
Oh. And they are black.
Oh, and so are my calipers.
And the hats on the brakes.
Edited by GTSBoy
Ok. So you have your preferences. Why the f**k come into my thread and try and downplay my preferences? Does it hurt your ego that I don't give a f**k about your little performance requirements????
  • Like 1
No difference in use with "street" pads (ie pads that work from cold). It can be a problem with things like rally use where you might start sub zero but do a 30 min stage flat out so you need to deal with a very wide range of brake temps.
Really the only issue with big brakes on the street is they are expensive to buy, might need larger wheels (also expensive) and discs and pads will be more expensive at replacement time too.
  • Thanks 1
 Share
    • From what I've seen and experienced first hand with those powder extinguishers, they're good to use to break a window and escape the car, and half the time then do f**k all to stop a fire. You just need much more than 1KG worth of powder. Not to mention, half the time it's an engine bay fire, and you can't easily, and do not want to completely open the bonnet, so you're left pretending to be an American Infantry... Spray and Pray baby!   And then 100% that shit is really destructive afterwards!   Realistically, those little ones at a race track might help you keep the fire from growing and give the fire marshal / truck a chance to actually get to you with their multiple large bottles.   For a road car, these days, prepare to deboard as quickly as humanly possible, and move to safety. Allow insurance to fix replace it (unless it's like a rare classic etc, then do nearly everything possible to save it!) Keep the little extinguisher with you to help protect other things around you from burning while you stand there singing "How can we sleep while our beds are burning?"   Secondly, powder extinguishers I freaking hate for indoor use, (this isn't really relevant to a car) as you will get a powder fog around you, and it can be disorientating.   When I did fire training when at BlueScope Steel, they have (had?) their own fire brigade on site. We did all the training, and at the end we were told, "If it's an indoor fire, and you need to use a powder extinguisher, we as the fire brigade would rather you just exit the building, you're more likely to get lost in the smoke and powder fog than do much help, so just GTFO" And pretty much that was what they said for most other fires too, grab extinguisher, if it's much more than paper in a bin fire, use extinguisher to get you and others out of the building to safety...   Part of me wishes when my Skyline caught alight many moons ago, I let insurance sort it out, instead of putting the fire out... part of me now says "But I've saved a classic before it was a classic!"
    • Hi all,  I have a older model of the Greddy Front facing intake on an RB25DET NEO Head. I've bought aeroflows fuel rail and injector kit (1000cc Bosche injectors) and I'm unsure if the fitment is correct. The injector o-rings fit in the intake hole but it's not snug. I can very easily rotate the injectors even when the fuel rail is mounted. The kit also came with multiple adaptors, they dont make it any more snug and using them raises the injectors up and i cant mount the fuel rail. I hope this makes sense I've asses a few photos.    Thanks so much guys.
    • So, to run the 4g aerials to the booster, I had to get access to the rear bulkhead....bit of a mission. Hot tip, don't offer to help change the rear shocks for a mate with a v37.... Remove seat base, 2 clips that slide forward to release it the it lifts straight out Fold down rear seat (pull in from boot) The side bolster of the rear seat is not connected to the middle parts that fold. To remove unbolt at the bottom bolt then push it up off the top hook Then there is a plastic surround behind the seat back, 2 pop out clips, 2 bastard clips, some swearing at it is out Pop the rear seat latch surround off Remove door surround lower trim then side trim  Remove c pillar trim - 4 clips, pull inwards not forwards Remove metal brace - 5 bolts 1 nut Then you have got to the rear strut top...what a pain!
    • If you really want squish back, you can have it put on the piston (at least to some extent).
    • Impressive. He's very very smooth.
