Few people have mentioned I should start a build thread so here we go!
In short, I've picked up a 1993 R33 factory RB25DET 4spd Auto and I'm going to be barra swapping it. I've built several factory Barra powered vehicles now and wanted to pick a nice light JDM shell to commit to. To start out, the car will take form with 350-400rwkw, which will be plenty to get comfortable in. I've put in a summary of some things needed to be done to the existing shell and also what the driveline will entail.
ENGINE
Built Greentop Barra on E85(Just the usual springs, gears, studs etc), GTX3582 GEN II High mounted, 50mm Screamer.
GEARBOX
Fully built BTR 4 Speed with high-stalled converter (1st and 2nd are tall gears, paired with the 4.36 auto diff assuming it stays alive will make for some awesome launches)
I aim to sell the motor short term from the car once my destroked projects have proven successful in the XR6T's (Falcons, just less muck around with R&D). Would be similar power level as before, just with a stupidly high capacity for revs (9k rpm+), pushing that torque back would help with traction too.
SHELL WORK
Full closed door respray in factory KH2 (GUN METAL), I'll be getting the body as straight as possible
Engine bay spray
Chassis Spray
Full rebuilt on suspension (front and rear)
Front end work (slight damage but have a full half cut so not to worry)
There is heaps more but I'll update as I go, I'll try keep it as comprehensive as possible for anyone using it as a resource.
For anyone interested, my YouTube is The Barra Specialist where I'll be documenting the whole build once I've restored the shell.
  • Like 5
https://www.sau.com.au/forums/topic/484731-barra-swapped-1993-r33-project/
    • Isn't there a fitting on the back of the balance tube? That's what the OEM boost gauge uses.
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
