Hello, this is definitely my favorite forum. I always manage to resolve my issues when I come here! :D However, I’m dealing with a problem I’m not sure how to address. I’m hoping to receive pointers or guide on my quest to solve this issue.
Issue: On cold start, my swapped 180sx with an rb25det will crank and idle normally, but as soon as it starts warming up. There’s a subtle backfire, little pops if you will. At operating temperature, the idle begins to fluctuate up and down between 800-1200RPM. Eventually, only when fluctuating RPM it will drip my 150A breaker at the battery and the g4+ ecu will lose power and shut off.  Or the ECU will shut off without dripping the 150A breaker and everything else stays on: radio, fuel pump, gauges, etc.
Questions:
1. What may cause the ECU to turn off?
2. How to I measure voltage to the ECU?
3. Is it possible there is a short causing the current surge to drip the breaker and make the ecu behave erratic?
4. Anything I should check?
Parts installed before problem began:
• GTR R35 Coilpacks
• Bosh donut knock sensors
• PRP trigger kit
• 270A alternator
• LINK G4+ lambda CAN wideband sensor
I did drive the car with all parts installed with one issue.  The ECU had a wideband sensor overheated code, which I resolved by addding a 200uF 12V capacitor. Other than that, I didn’t deal with issues until this.
Any help is greatly appreciated. Thanks!
Edited by Eric0
Added more description
https://www.sau.com.au/forums/topic/484733-idle-fluctuating-then-stalls/
The 150A breaker is it a quality item? Thats a big current trip
Does the afr change and go lean? sounds like a possible lean issue with popping or if rich check coil voltage.
Check IACV resistance when cold and warm. Also disconnect and see if same issue occurs.
Did you upgrade the alternator wiring when you did the upgrade?
Check wiring at alternator as could have a steel/braided line running over the B+ terminal
Hi Robbo! Always lovely hearing from you! You’ve helped me with a lot of issues!
Yes, the 150A breaker is quality and I’ve never had it trip until recently with the idling issues. All alternator associated wiring was upgraded to sustain high current.
I just had Jono go over my ECU and he was able to pin point the triggers being a reason why the stalls out. The ECU had a lot of trigger errors.
Not sure why the breaker went off, or ECU shut off, maybe due to bad trigger feedback?
I will resolve the trigger issue and see if the weird behavior persists.
  • Like 1
    • Interesting. My tuner said after the tune that my fuel economy would be better but it is the exact same from what I could tell even though my car was running rich before lol. How much do km do you reckon you get on a full tank of petrol on your commute?
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
