In relation to this video:
A few things in here really made me facepalm. It uses belts to drive the cams and oil pump, which wouldn't be too remarkable except that they're INSIDE the engine, and while I would hope that they used a special composition belt, the state of the belts in a short service life leads me to think they're pretty much standard rubber timing belts that last about as good as you'd expect bathed in hot oil their whole life. In this teardown, the belts appear to have caused the destruction of the engine.
Also, the timing belt isn't keyed to the crank. Yep, that's right, it only keeps timing if the toothed pulley remains torqued enough.
I shouldn't be surprised that this exists, but I keep wondering why it exists. Even an amateur engineer can see these obvious failure points, and yet a company with more than a century of experience in motor design has made this engine.
Some things might be easily explained by cost cutting. Not keying the crank technically saves on a machining step. But belts inside the engine?
The more sinister side to all this is 1) planned obsolescence after about 5 years, and 2) difficulty in maintenance and repair by either the consumer or 3rd party repair.
Take for example the timing belt, it's no longer a matter of simply synchronising the belts teeth to the correct teeth on each pulley. It now has an infinitely variable pulley which needs some special tools to get it synchronised.
Does anyone have any insight into the industry? I can't believe these are ideas originating with engineers, but rather the accounting department. Or is that even too generous to all engineers, is there also a culture of amorality in which they're in the business of creating the ultimate disposable consooooomer item? Let's not forget VW's dieselgate, there's plenty of engineers willing to go along with some shady stuff.
The lack of keying the crank hub to the crank is a cost cutting measure. Getting everything to be perfectly clocked on the crank and keyed correctly takes more time in production and assembly. Modern engines use nickel-diamond one time use washers that generate incredible amounts of static friction when torqued to spec. All of that can work as long as you do the math correctly. Obviously the problem is when you look at stuff like the BMW N54/N55 they don't do the math correctly and there's not a sufficient factor of safety to avoid spinning the crank hub when people use the DCT kickdown too often. You don't hear about Mazda's MZR/L-series engines/Duratecs spinning crank hubs and losing time en masse even though they are built the exact same way. Also let's not forget that people absolutely mangle crank keyways on RBs so it's entirely possible for the timing gear even on traditional designs to be held on purely by crank bolt torque.
Belt in oil is not the same as a traditional dry timing belt where oil causes it to fail rapidly. The belt is built for engine oil, although like timing chains if you stretch oil change intervals too far it will cause the belt to age faster. The design logic behind using those is first and foremost about fuel efficiency. Belt in oil has less friction than a timing chain. This alone is enough for most manufacturers to go for it when fleet average fuel economy drives so much at these OEMs. On top of this though belts don't transmit crank harmonics as strongly to the cams as a traditional timing chain. The belt can be narrower than a timing chain which means the whole engine can be smaller to cram more electronics in the engine bay or whatever else is fighting for space. Unlike a dry belt you don't have a bunch of oil seals on the front of the engine to separate the timing components which is another win for production time, part count, and cost. Those belts are also designed to last something like 150k mile change intervals which is about when the whole front of the engine has to be taken apart anyways. Anything that doesn't use hydraulic lash adjustment will also need a valve adjustment at the same time so either way you're doing a pretty major overhaul. RTVed front timing covers are usually also leaking pretty nicely by that point regardless, especially when engine mounts are attached to them for transverse FWD commuter cars.
Personally I think when assessing what engine/car is worth buying boiling it down to simple spec sheet comparisons like "belt in oil" vs "timing chain" vs "dry timing belt" is really not a good idea. I can show you timing chains that need service at frankly incredible intervals like the BMW N20/N26 engines that frequently self destructed themselves at 60-80k miles from timing belt stretch. I have seen RBs turn their timing belts to shreds well under 60-80k miles because of unexpected interactions like overboost fuel cut causing the belt to catch the crank trigger wheel. I can show you GDI engines like the BMW N63 that are an absolute nightmare to service or something like a Toyota M20A which is comparatively hilariously easy. It is tempting to boil the world down into "after x feature all engines suck" but it's really not that simple.
  • Like 4
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
