Hi Guys,
I am building a Nitto Stroked RB28 with all the goodies, fully Ported/Polished Head, Kelford 182-SE Cams, VR38 Coil conversion, PRP 32T Trigger kit (or similar) etc. Looking at using either the 6Boost T4 Divided Manifold or Hypertune T4 divided. Which Turbo will give me the quickest spool from around 3500rpm to 8500rpm without running out of puff? Looking for around 750 - 900hp.
Thank you for your input.
https://www.sau.com.au/forums/topic/484757-best-turbo-for-early-spool-rb28/
Hi, Forgot to mention that the car will run mostly on RON98 But will be E85 capable. I have been told either Precision 6870 A/R 1.00 with Artec 70mm Big Daddy "V" Band Manifold or Garrett G35-1050 A/R 1.05 using T4 Twin Scroll. Both of these sound great But as this will only be a street car, Which Turbo set up will give the best Response or should I stick with Twin EFR'S?
If wanting quickest spool/response then its twin scroll efr set up. For >750hp, efr8474 or larger. If not efrs, g35-900 or g40-1150, if wanting cheaper, gtw3884r-67mm or gbc37-900, all shoud be in twin scroll set up for better spool/response. Skip g35-1050 at it has mismatched wheels, compressor too large for turbine.
I run a gen2 6466 1.00ar divided T4 on my 2.8 and it spools wickedly fast. If you're aiming for 750-800whp, I think it's a great choice. If you're looking at 900whp+ I'd go 6870.
Road car, Borg Warner is the only answer. Anyone who thinks anything responds great has not felt the transient differences that That Ti-Al wheel provides. The turbo is the single most important part of anything. The right turbo will have much more effect than going from 2.6 to 2.8L.
  • Like 1
hey mate
check my build thread i have pushed the 6466 as far as i can go on a HKS 2.8 with Rams head and 276 cams
got 820whp and all in just after 4k
good for a 9.6@146
copped years of proper motorsport use
I am going to swap over to a g35900 now just for shits and giggles to be honest and see how it all compares
but i do recommend a 6466 on a 2.8 as a really good allrounder turbo
  • Like 2
24 minutes ago, Dr Evil said:
Hi Hattori, The G35-900 was also one of the favorites, please let me know how you get on :) I need to order something in the next few weeks. Also, What Manifold? Hypertune T4 or 6Boost T4 or Artec V band?
Wouldn't the manifold you buy be dictated by the turbo and rear housing you choose?
You're chasing 'early spool' so it would make sense to choose a T4 TS manifold for a T4 TS turbine housing.
I went 6boost t4 twin scroll
1.15 rear housing I gained alot and lost minimal response
2013 my options were 6boost or a bespoke manifold so that's why I went 6boost.
Ild try Artech if I went again
I am currently building a Nitto 2.8, GSC S1 Billet cams, Headgames pocket port/shimless bucket head in an R33 GTR. Shooting to make a reasonably responsive 850whp for a street car when in "kill mode". I wanted to go the EFR 8474 Black series, but they are no longer making certain EFR's until further notice. I ended up getting an awesome deal on a Divided T4, 1.0 AR turbine Precision 6870 with the T51r mod for $2100 brand new. This turbo is very similar in size to the EFR 8474, but obviously uses different materials. I think spool should be around the same (all in around 4,500rpm) and I will be revving to about 8,500. Also using a PPG sequential, so once its spooled, it should stay there, which is why I may consider going larger turbo later. This will all be sitting on a Full-Race divided T4 twin 44mm wastegate manifold. My theory is that I will try the "smaller" Precision 6870 before jumping up to a 9180 or even 9280 EFR that are actually available. My engine is almost finished being built, so the car should be running in the next 4-6 months from now, although it wont likely be tuned on E85/full boost for a few months after initial startup. I will stay tuned and update once I have results.
  • Like 2
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
