"Worth it" depends what you want from the car....if you love the car and want to keep it long term it is probably a good option.
If you just want to get to Woolies faster, you would be better buying something more modern.
It would probably cost a few thousand, even if you find second hand factory turbo parts. You need
Exhaust manifold
Turbo
Water and oil lines for the turbo (and places to tap them into the existing systems)
Dump pipe to suit (often custom)
Exhaust to suit
Intercooler in intake
New ECU and tune
Larger injectors
Boost control
Depending on power goal - new clutch or auto trans upgrade
probably plenty of other things I haven't thought of, but that would be a few thousand to start.
Or buy my car. :D
That said, I don't think I'd sell, because I know what it'd take to do it again. Really you're buying/building a complete car from scratch that just happens to have the body you like. It is never 'worth it'. It is far more sensible to sell it as is, then go buy a Mustang. MUCH easier, and cheaper too.
Let's just say that it is probably more "worth it" now than it has even been. Given the relative unavailability of GTTs and the elevated prices for them if you can find one for sale, doing the work required to turbo an NA car is not as financially silly as it used to be.
It's still financially silly. Just not as bad as it used to be.
Better option is still to do what Greg did. Put an LS in it. Or put a VQ37 in it (if you can handle the obscene noise they make). Add valley mounted intercooled supercharger for boostiness without needing to plumb up turbos. Hopefully add some more tasteful noise to drown out the exhaust too.
    • Given by the sheer number of questions about offset, absolutely not. If you had the information formatted this way: Space from R34 GTT hub to outer arch = 100mm Space from R34 GTT inner hub to nearest suspension arm = 90mm. (making this up) Buying a wheel that was advertised as Enkei RPZ5 Diameter 18in Width 9 Distance to arch = 84mm Distance to suspension arm = 76mm 100% of people would know instantly if it fits. They would absolutely also know instantly how close it fits too, and no questions would need to be asked. You would know you would have 16mm from the guard and 14mm from the suspension arm.
    • Ah ok, for example for the apexi ecu I heard that it's pretty limited with the information it can give you. Also not sure why Nissan used the consult port over the obd2, what the idea there was.
    • Diagnosing with and without is mostly the same. You need to know, as Duncan asked, and what conditions. Car hot, cold, idling, driving, if while driving what rpms, is when you're varying, or is it when held constant.   From there it's understanding what can be causing it. Starting with pretending all of the sensors are correct. Which means if it's going rich, why would it be thinking more air is going in than it is, and under what conditions. So things like if only when under boost, it could be be a loose intake piping joint. It's just understanding the system, and understanding when/how the problem occurs, and then if it's only occuring in specific scenarios, what can be causing it.   ECU specifically, if it's aftermarket, it'll have software you can use, for the Skylines on factory ECU, there is Nissan Consult you can use. Most ECUs have a way to get data from them.
    • How do you go about diagnosing ecu's that don't have data logging, is it more experience at that point and just trying out things that you think will fix the issue?
    • Stock O2 are basically useless beyond anything at stoich. Any misfire will also be seen as lean. The stock O2 also read a collective exhaust gas volume, not each cylinder. Sputtering and missing means not each cycle is firing, and some are. Which means even if rich, as shit, on cylinders as they miss, they'll read lean, but the cylinders that did fire will read rich, and combined, well, they can read anything from rich to lean.   Start with the basics before even going looking at sensor values.   Edit: I say the above, and that's coming from the guy with a few thousand dollars worth of scan tools sitting right beside me right now that I use frequently for my job.
