I took my Skyza out to a wet pan event and whilst waiting my turn my car just died. I Jumped it and my voltage was just over 12. Keeping the revs up I was able to keep the car running. But voltage was still quite low. Then all of a sudden 13.8 for a bit then back down. It kept going up and down my whole trip home.
does this sound like a dodgy Alternator?
https://www.sau.com.au/forums/topic/484767-rb25-charging-issues/
On 27/6/2023 at 8:56 AM, GTSBoy said:
And let's not bother finding out what is actually wrong.
Hey mate, I think the problem is actually the alternator light. I don't Chet the charge light coming on at all. Here is where it is currently plugged in to. Perils of picking up someone else's project. In the pic the circled bit is where the light wire is going. It is a white/red wire on the other side
On 30/6/2023 at 5:54 PM, GTSBoy said:
Yuh, so break out the multimeter and check the wiring. Pull the dash out and check the globe locally.
Ok, I have pulled the cluster out. The bulb is fine. There is power at both sides of the globe.
does this mean the Alternator is not earthing the wire when the ignition is on but car not running?
does this tell you anything?
If you have power both sides, then yes, there is no earth. That wire runs through the alternator as the exciter, which causes it to start producing current, which it will not reliably do without the excitation. You can follow it on the wiring diagram to see where it goes.
I noticed there is no earth wire bolted to the back of the alternator. I clipped my test light on this bolt and tested a live wire to see if it is grounded and I got sparks. Does this mean my alternator is possibly just not grounding enough?
Impossible to say.
Get the wiring diagram. Make sure you have the same wiring as the diagram. If you have the same wiring, and it has continuity where it should, AND shit's not working.....then you suspect the alternator has a fault.
Just don't mistake the main power stud with a grounding point, there are a few different model alternators on these, but AFAIK they all have an M6 stud for the positive and an m5 bolt or stud for the earth.
It does need to be earthed to charge properly
It is a little bolt that I am talking about. Definitely not a stud. It doesn't have power just not earthed
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
