Rust on the wheel wells - should i be concerned?
Was doing brakes and noticed the coating was peeling on the wheel wells. I started peeling some off and found this rust. This is my first project car and not sure how to tackle this and if i should be really concerned. Anyone have experience with this? IMG_5573.thumb.JPG.1452fd1003a0899a13d3ebf082385143.JPGIMG_5574.thumb.JPG.f09c9ec5beee31561bba2bfe864ad2a2.JPGIMG_5575.thumb.JPG.bfddd6c9819d117b699358525644e43a.JPG
Remove old coating, wire wheel affected areas and treat with product, prep and reseal with your choice of product.
Depends how deep the rust goes  may need to do some patch panels.
Had similar on one of my cars and did the above, used a underbody coating after treating and repairing sections.
Yes, you should be concerned. How concerned? Don't know. Poke a screwdriver and see how deep the rust goes. If it makes a hole you need to weld in new metal.
  • 1 month later...
1. When and where do i stop peeling back the current coating? Do i remove an entire section? because the wheel well is connected to the underbody and the coating spans the entire bottom side of the car.
2. After i clean the rust area with wire-wheel, how do i prep and reseal the surface? Since the current coating peels in irregular shapes, would i just spray over the existing coating to blend it in? (Not sure if that makes sense. For example, if I'm painting a house, each room is sectioned off so its easy to tell where and when to stop. But in this car, the wheel well, is part of the frame and goes to the underside)
20 minutes ago, GTSBoy said:
1. When you stop exposing rust, and not before.
2. Any texture left on existing coatings with abrasives will provide a key for the primer (proper primer goes on bare metal first).
What do you mean a key?
  • 1 year later...
Update: I started peeling all the undercoating and this stuff was really tough to remove when it was bonded properly with the metal.. The initial top coating (rubber) came off easy, but there was this primer layer, sort of vanilla colored stuff that was extremely stuck on to the bare metal.
This is what it looks like halfway removed. You can see the silver bare metal, then the vanilla colored primer, then the black rubber undercoating. IMG_0169.thumb.jpg.0a6e4399221c777946228a7859bc5300.jpg
This is what it looks like when i was done. This took A LOT of elbow grease. Ill upload pictures tomorrow of it painted. I used this stuff from Eastwood called Rust Encapsulater plus.
4 hours ago, Murray_Calavera said:
So when you say painted, do you mean sealed with something like rhino lining or line-x?
No, i used Rust Encapsulator Plus. Eastwood Rust Encapsulator Plus Quart
https://www.eastwood.com/eastwood-rust-encapsulator-plus-quart.html?gad_source=1&gclid=Cj0KCQjwo8S3BhDeARIsAFRmkONxM27m1gqntP8Uw-ktrfx9g2Eq_UtGGcqlM0Sn3sYdcU1RyivLnNEaAi7LEALw_wcB&wcid=18675710285&wickedid=657100129148&wickedsource=google&wv=4
38 minutes ago, kevboost7 said:
its not really a truck bed liner
All of that material you found hard to remove is hard to remove for a reason. If the factory could get away with using paint I'm sure they would. If I was doing the repair, I'd be looking to replace the sealant I had just removed with something equitant or better.
Did that stuff come from the factory? I wasn't sure if the undercoating was sprayed afterwards to hide the rust.
 Share
    • I was actually going to try and dig out a datalog with turbine speed and EMAP haha
    • Wait until @Lithium posts a compressor map and tries to explain what's going on. There is a strong possibility that the OP lives in a digital world and is not comfortable with analogue machines. A turbo is just about as analogue as it gets, with plenty of non-linear behaviours added in on top. Most of us who think we know how they work are actually only getting by on 2nd and 3rd order mental models that abstract away from the actual physics and bring it back to the sort of kindergarten level concepts we can hold in our heads. This is important when you need to hold 10 such concepts in your head at the same time. You need to reduce the complexity of the individual concepts to allow them to be simultaneously held and manipulated. Too much complexity in the base models makes it very difficult to make them work with each other mentally.
    • It could be. It might not be. It is impossible to know without context by asking the owner or the tuner on the day and knowing what they were doing/not doing/attempting to do. You said earlier this is hard to understand because to your mind, a turbo is at full speed when it hits its spike. This is not true. The turbos actual speed is defined by how much air is being forced through it via the exhaust, unless you control it. The spike you are seeing at ~whatever RPM it 'spools' at, is where boost control is starting. If there were no boost control the turbo absolutely would be spinning much faster at 7000rpm than 3000rpm, every single time, on every single engine. Boost control keeps the boost controlled within the limits you ideally want. If it were uncontrolled you would have two scenarios 1) You have a turbo that hits peak RPM and CFM (not boost) at the redline of the engine. This would work, but most people want more boost earlier. 2) You have a turbo that hits peak RPM well before the redline of the engine (say, 3500), and you explode the turbo by redlining the engine. (say, 7000rpm). If you don't want exploding things, or lag, you design a turbo system to come on when you want the boost to be useful, and then not overspin itself into oblivion by using some form of boost control, to control the boost pressure accordingly.
    • Yep. >10 posts required. Prank can relax that for individuals when required.
    • @PranK is there a restriction on posting pics based on post count?
