https://mcasuspension.com/
https://www.shockworks.com.au/
Contact one of these companies, listen to what they say and buy the recommended product.
Nothing is cheap when it comes to good suspension
  • Like 3
I was about to say Ohlins at $3000 is a complete steal, (depending on.. model?) and well worth opting in for if the price difference is as little as that compared to the top two links.
  On 27/06/2023 at 1:22 PM, kevboost7 said:
What coilovers are you guys running?
Expand
When you say "coilovers", are you referring explicitly to proper small spring diameter adjustable coilovers, or "any suspension unit that fits in the same spot"? Because the latter includes things like stock springs on aftermarket dampers, or aftermarket springs on aftermarket dampers.
"Coilovers" is usually expressly reserved for small diameter spring adjustable suspension units. The amount of "adjustment" available is a wide variable, but minimally here we'd be talking about height adjustment.
Anyone saying they have Bilstein based suspension, like me for example, cannot really say that they have "coilovers". My springs are stock format and could be retrofitted back onto stock dampers. Can't do that with coilover springs.
haha that might be a little hair splity, because literally all R chassis skyline have the coil over the shock.
FWIW, both my Bilstein cars have been converted to adjustable spring heights using a circlip groove machined into the shock body which supports an adjustable height spring seat
  • Like 1
Expand
No, they come with the grooves. He just added 1 - 2 more of them.
  On 28/06/2023 at 8:23 PM, Duncan said:
I know it's getting off track, but I mean the circlip groove holds up a threaded sleeve to adjust the spring seat height.
Expand
Yes. Same same. I'd have to dig through my comms with Gary to find the detail, but obviously enough they need at least 1 circlip groove to hold the perch up, and they have at least 2, and Garry just adds (or added, to keep the tense correct) some more.
Edited by GTSBoy
I know it's getting off track, but I mean the circlip groove holds up a threaded sleeve to adjust the spring seat height. Not a great pic but you can kind of see the setup
Expand
I know what you're talking about. I installed a set of bilsteins front shocks on my F-150 truck. I was so surprised when i read the instructions that the tiny circlip could support the weight of my 5000-6000lb pick up truck.
  • 3 weeks later...
