Hello all, I’m in abit of a predicament as my coolant leak fixes are beginning to look like ass, and when trying to find this replacement part to hopefully fix my hose management, it seems long gone. I have tried places like amayama and souqparts. Anyone have any ideas on where to source this?
appreciate any input :)
https://www.sau.com.au/forums/topic/484772-rb25de-neo-rear-water-spigot/
Let's just consider this more fully then, shall we?
Not available anywhere? Check.
What is it made from? It's made from a threaded fitting and a couple of pieces of pipe.
Could it be made in 2 hours by someone with a welder and some raw materials? Maybe a lathe if you want to make the threaded part from scratch? Yep. You bet your girlie arse it could.
Would I make it from scratch if I needed it? Yep. Bet your girlie arse again.
Would I even go to the lengths of getting it cad plated? Probably. At least zinc passivated. It's not hard to do it yourself, but you could always sneak it into a basket at a plater's for a couple of beers.
Useless advice? No f**king way. You are just typical of the weenie approach to everything that the modern generations have adopted. If it can't be 3D printed or bought from an on-line vendor, it is IMPOSSIBLE!
Your attitude is the attitude that sucks. Go file your nails and have a facial.
Edited by GTSBoy
  • Like 1
Yah ! Id remake it ! And remake it in brass so you don't ever have to do it again.
Can you get it off the block ?
If so then take it down to a fitting place and grab a hose barb with the same block thread and main tube size.
Also grab a smaller hose barb to do the right angle one coming out of the main one.
Cut off the threaded end off the smaller hose barb
Drill a hole to the main hose barb the in the same position as the original small one and then press in the small piece and solder it into place.
Did similar to my R33 to replace rusted out, nickel plated, steel fittings over the years.
  • Thanks 1
Hey man do you remember the thread it was? I read somewhere it was a 3/4 bsp but it won’t thread it so now unsure
Nope that was quite some time ago and all I did was take it out of the block and took it to them and said "want this in brass please" !
Of coarse they said " don't have it with the sticky out the side thingy " and then went through the above to make it happen.
I think you will have the same scenario and anyway, one way or another, the original has got to come out of the block.
2 hours ago, PLYNX said:
Also I don't really think its 3/4 BSP as that's imperial !
Probably got to be metric coming out of Japan !
Maybe ! Should be !
Could be wrong though !
Nope. Jap threads are BSP by another name. JIS PT = BSPT (where the T means Tapered, not thread, as is commonly mistaken).
Note that I don't know if the target thread here is BSP/JIS or something else either. But.... if you've got the original in hand, then you have all that you need to know. Just measure the thread.
  • Like 1
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
