I just went through this same issue in the USA. The part is discontinued, and there was only a couple really beat up senders for sale on ebay. These are very tempermental, and break/corrode very easily. I found a company in Seattle, WA that makes aftermarket senders and I had them make me one to my specs. Its a 0-90ohm sender, which is the same as OEM Nissan. Its 18 inches long, and is E85 compatible (which costs extra). The company is called ISSPRO. The custom part number should just be "R33". I dont see it on their website, but if you call them, and ask for Don, he should know exactly what youre talking about. I think they charged me $175 plus shipping, but honestly I didnt care because most of the used, beat up OEM senders were that much or more. Hope this helps!
EDIT: Their custom made sender slips into the factory "clamshell" of the OEM sender. I popped open the OEM sender by pressing on the tabs, opened the clamshell and gutted all of the OEM electronics. Then I trimmed about 1" off of the top off of the OEM clamshell, and slipped the aftermarket sender in. Drilled a couple holes in the clamshell for zipties and ziptied the sender at top and bottom so it doesnt bang around inside the fuel tank or clamshell. It uses the OEM bracket inside the tank and hangs there just like normal.
Edited by StubbyFoil
  • Thanks 1
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
