SmItleR, Paragon... you didn't answer his question.
The Greddy (Goo-red-ee :P) intake plenum is a fairly popular conversion in Japan. I wouldn't say that *everyone* considers it, for example, a 400ps ECR33 has the Greddy plenum, yet a 450ps HCR32 doesn't (stock intake)... go figure.
I guess it boils down to what the person wants to do with the car. The ECR33 has a better chance of 550+hp with the RB25DET, therefore you're more likely to see the Greddy plenum on RB25DET equiped cars. Well, lets just say 50% of the medium-hard tuned RB25DETs have the Greddy plenum (or similar), and less than that for the RB20DET in Japan. Going out on a limb there, but you get the idea...
https://www.sau.com.au/forums/topic/48478-greedy-plenums/#findComment-974958
They do change these items but I'd say it would be the last thing to change if they do...plus they cost a fair bit. One would go for a larger throttle before doing the plenums.
Hell the Evo 4G63 plenums is great, demo cars are pushing out 600ps with them. We only touch the exhaust manifold side.
https://www.sau.com.au/forums/topic/48478-greedy-plenums/#findComment-975628
Of the benefits available when fitting the Greddy unit to an RB25, additional power isnt really one of them.
On the more heavily modified cars particularly, as Rezz said they are common but I believe this is more for the fact they greatly simplify the intercooler pipework, removing the notorious U-bend and requiring a much shorter pipe between the cooler and the intake plenum itself
https://www.sau.com.au/forums/topic/48478-greedy-plenums/#findComment-975995
thanks heaps guys. yea was looking for info as, with cams for the rb25 people have pick up on the common jap commbo so i am looking to do the same but with the greddy plenum so to speak. Its a part that doesnt gain on the dyno but could make a quicker car buy response and heat soak just interested to see if its popular or worth while on the jap scene.
What i can gather is it is but the mod takes place toward the end.
im realy aiming for 380rwhp but am coming across alot of small problems including a vacum leek that cant be found and looks like the plenum will come off and new gaskets and hoses installed. Loking at the price of these plenums they seem to have droped and i could get one for a 1000 or just under, so now would be the time but ive still got stock cams and exhaust manifold which seem to be done befor a plenum upgrade.
https://www.sau.com.au/forums/topic/48478-greedy-plenums/#findComment-976058
    • Saruthewhite hasn’t been on our site since November 2016 sorry mate
    • Note when Duncan says that, he means "when you're not using the correct lifting points on the sills, because you want to work on the sills. A 2 post hoist is not appropriate for everything anyway, and working on the sills is a good example of that, because the arms go under ths sills anyway. You're better off finding another way to support the car off the ground. Beyond that everything else D said is correct. Only the dedicated jacking points are the correct place to lift. Anywhere else is incorrect, extra caution and awareness must be used, etc etc.
    • Your off site links didn't work for me, and in any case it is easier for forum members if you post the pic directly either as an attachment or a link so the information is all in one place. That aside, the sills are the correct place to lift the car, whether with the factory jack or a hoist. Yes you should use rubber blocks with a slit for the seam on a hoist to avoid bending the pinch weld (where yours is currently bent, just bend it back if possible eg vicegrips), and be aware of the height you need in the blocks to clear any sill extensions to the hoist arms as it lifts If what you are doing needs access to the sills, the rear subframe bush would also be strong and secure. I'm not sure what you mean by sidemember (maybe same part I mean by sills) but be careful that your front support point is not too far back as the car is very front heavy and could overbalance.
    • Here's my first iteration - white duct tape so color is off, but this is just a straight line across the bonnet lip. From a geometry standpoint, this is probably closest to what a GTR has. Next up is some $5 white pearl vinyl and some rubber door sill trim, applied to the BACK of the bonnet lip. It's more accurate placement to the GTR, but also follows the body lines on this setup a bit more. Couple more pics on this config incoming: Again, a $5 vinyl and rubber job, it's  POC still and not how I'm gonna run this part. But one thing I'll note is that the black trim does need to "straighten out" a bit, and instead of going completely along the line of the bonnet lip, might be better suited to wrap over the "horns" of the bonnet lip, giving it a less aggressive curve up at the ends.  The correct way to do this would be to paint it body-matched and then decide how you want to make the black line. If you used paint or a pinstripe, you could have the black line go straight to the corner of the headlight where the rubber strip typically meets the headlight on a GTR.   Hope this helps!
