Hey guys!
Does anyone know the process of registering an engine swapped car in NSW? Provided the engine swap and all mods have been fully certified and I have an engineers certificate, what are the next steps to follow, to register the car?
A quick google search says to change the engine details of my car with Service NSW?, i need the following -
  • your proof of identity
  • your current registration details
  • one of the following:
  1. a Vehicle Compliance Certificate (if applicable)
  2. AUVIS (unregistered vehicle inspection report)
  3. HVAIS (heavy vehicle unregistered vehicle inspection report and heavy vehicle safety check inspection report)
  • the PDF form – 'Change of Records'.
Does anyone have experience doing this?
Are these the proper steps to follow?
Just take the documents and head into Service NSW?
Any ideas on fees associated with the process?
Any help is greatly appreciated.
I guess the questions we need to ask first are;
  • Is the vehicle currently unregistered?
  • Has the engine swap already been done?
  • Do you own this vehicle?
  • Or are you proposing to buy it with an existing engine swap and also currently unregistered?
The answers to these questions will describe the shape of the hole you're digging for yourself.
My understanding, if it is currently NSW registered is you need the blue slip to update the rego.
If not registered you need all the doco to establish a new rego - blue slip, pink slip, import approval, weighbridge slip, proof of ownership etc. AFAIK any engineer report is required for the blue slip, not establishing the rego
Currently registered.
Engine bought, swapping to commence soon.
I am the owner.
That's what my understanding is as well.
As mentioned before, Service NSW says that to update the rego i need either a Vehicle Compliance Certificate (if applicable) aka Engineers Cert, AUVIS (unregistered vehicle inspection report) or a HVAIS (heavy vehicle unregistered vehicle inspection report and heavy vehicle safety check inspection report).
I will get it engineered either way, so my understanding is, in terms of documentation, I just need an Engineers Report, a filled Change of records form and fees to "re-register" it.
Car is still registered so technically its just a change or records aye?
And if it goes out of rego, according to their website ill need either one of those three things mentioned above to register it?
https://www.service.nsw.gov.au/transaction/change-vehicles-engine-details
According to them, only need a Engineers Certificate or Blue slip.
So since i will be getting engineers cert, wont need the Blue Slip aye?
My reading and understanding is that because it is already registered, Service NSW just need a blue slip with the new details (engine number etc).
You need to check with the blue slip station on what they need, that is probably where the engineer's info comes in.
This can't be answered correctly without knowing what engine is going into what car.
Some engine swaps cannot be registered, some swaps will require engineer certification (+blue slip), some engine swaps will be blue slip only. You always need a blue slip, that's how the records are updated on the system with the new engine number etc.
  • Like 1
Putting a 6.0l LY76 from a newer 2009 VE Calais into a 2003 Nissan Skyline V35, which came with a 3.5L VQ35DE. Engineer says its doable and can be engineered provided it passes emissions and brake tests etc. That's all the contact I've had with him
Would I still need a blue slip if its engineered? Wont an engineers cert be a more through inspection, compared to a blue slip?
I don't know why you're so hung up on this blue slip thing. It's like a $40 piece of administrative paperwork and 30 minutes of your time.
You are going to go through hell getting the car certified, I'd be more worried about that. (I'm not saying it won't be certified, but it is not a fun process and is bloody expensive and time consuming).
If the Blue Slip is an easy enough thing to get, then am not too bothered about it now. I'd like to have a fair idea of whats required so i can make plans to get them done, and have the paperwork ready. If i can save 30mins of my time and $40 in the process, then why not lol.
According to what i've read, the hardest thing to pass with engineering is emissions. That's what everyone fails at least once. Most engineers say if its a straight engine/tranny/diff sway from one car to another, then its not too hard to certify (which mine is). Getting bigger brakes is another thing, which my car already has.
A to Z imports will be handling all the Engineering and Emissions stuff - https://www.atozimports.com.au/
Also this is what service NSW says about registering a modified vehicle
The people who fail emissions testing are the people that don't treat it as something that needs to be addressed as its own thing. People turn up with their modified cars, as they intent to run them on the street, and then unsurprisingly fail.
If you have the correct spec cat(s) and correct tune you'll pass first go. Are you able to use the factory ECU for this swap?
Also have you 100% locked in everything with your engineer, as in all the mods it will have and locked in a price? I've seen quotes blow out like crazy and plenty of engineers playing the 'oh actually, just change this little thing and bring it back game' next minute your bill is $2,500.
Step 1. Engage engineer, pay for initial inspection and their guidelines about what you want done then wait for the reply, will cost you a bit
Step 2. Do what the engineer says
Step 3. Get the engineer to inspect and hopefully sign it off, will cost you a bit
Step 4. RMS, you are putting a larger non Nissan engine in, so it will need all the bells and whistles IRT safety and emissions testing, will cost a little
Step 5. RMS papers work and rego stuff, will cost not alot
Step 5. Skids
  • Like 2
Step 5. Skids
Almost perfect list.
Small correction, the emissions testing needs to be done before the engineer can sign off the car. They are certifying that the car meats the Australian Design Regulations based on it's year of construction, they will need to view the emissions printout to be satisfied that this is the case.
I agree, skids are an important part of the engineering and registration process.
  • Like 1
  • Haha 1
Bought the newest Euro 6 Cats for the build. According to what I've read, i need to pass the emissions standards of the year of my car's manufacture date,which is 2003. My car came with Euro 3 standard cats. The L76 engine came with Euro 4 cats. So my cats are solid. Yes ill be using the Calais stock ECU with a custom wiring loom from the states, to ensure all the stock gauges etc work. Will be doing the swap and an "emissions friendly" tune before i do engineering. Engineer will be consulted before i do any mods.
Engineering at A to Z motorsports will cost $900-$2100 max, according to them. I've set aside $2500 for this. If it exceeds this amount, am f'ed 🤣💵
  • Like 1
Step 5. Skids
Thanks bro!
haha well you've already put aside the $2,500 that I mentioned, I hope you still have quite a bit of change left. Fingers crossed!
I expect that you will pass emissions first go. Yes you are correct, the standards that you need to meet are based on the year the vehicle was manufactured. It sounds like you've got all your ducks lined up which is good.
Hahahaha, thanks for the encouraging words mate. I did a fair bit of research online and asked around before i jumped into this. The whole swap if registered successfully, will definitely be unique. One of a kind in NSW 😉. A to Z do all testing in house. They use the dyno method to test emissions. Even if it fails, they will know what needs to be done, to pass it. Also they're based in QLD, so they dont seem too expensive or "strict" like the lot back here in Shitney 🤣
I would have gone RB or 2JZ swap but the engines are older than the chassis, therefore harder to engineer. I am essentially putting a newer engine into an older car with the L76.
Once engineering is done and i have paperwork in hand then nobody needs to know if the car gets cammed or something 😉😉🤣🤣🤣
    • You are perhaps suggesting that it is not a super car? Well....it's not an AU.
    • Dropped the MX5 of this morning to get the hardtop colour matched and some PDR done, they are also going to give it a buff to remove some "stubborn" swirl marks and light scratches in the clear coat Over the last few months the poor little thing has copped some shopping centre car park abuse, I try to not park in them, but hitting Westfield's a few times over the last few months has taken its toll, nothing really bad, but enough of a trigger for a "while we're in there" thingie  Once it's back and all the one colour, with a few dents and mark's removed I'll give some of these products a go and see what they're like
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
