Nissan R33 / GTR Gearbox internals into GTST
I assume that Nissan give you a tiny little jack in the back of the car, with the spare. They expect a random human to be able to tighten a wheel up enough. Then I assume a mid 40's person putting a wheel on with the equipment in the boot is considered 'okay' probably. Maybe. Someone had to think of this. I would wager wheels won't fall off from anybody using better equipment.
Are there any wiring looms that weren't swapped? Were all the dash looms changed etc?
OK, so all I can suggest is that - if you have all the parts, and you have all the wiring looms, and you have all the electronic modules, then....it really is just a wiring problem. You likely have a damaged wire, pin, etc, somewhere.
By DraftySquash · Posted
Yup, bought this bad boy and hopefully it will be ready to pickup today. Had $5 credit on top of it so it worked out really well! -
Yeah it is really until until you get a feel for it....then it is easy. Which is no use to you really. I'd buy that torque wrench. One thing from sure, many (most?) tyre shots overtighten the f**k out of wheel nuts, so don't worry if they were tighter when you tried to take them off compared to when you do them up. I've had some crazy tight ones come back from shops, quite apart from the potential damage to the thread, I can't see a smaller person taking the wheel off on the side of the road
