Hello all about 5 weeks ago my 1995 White Skyline was stolen from near the south on ramp at safety bay rd. It was seen at a bottle shop at the end of Dampier Dve.
Cops nearly caught the car but they managed to get away. I don't expect to see it again just putting it out there.
I have to resize the pics before SAU will accept the image thanks in advace
https://www.sau.com.au/forums/topic/484799-stolen-r33-gtst/
  • 6 months later...
