Hi all
Any reason not to get the Kelford Drop in springs for RB25DET NEO?
RB25DET NEO “Drop-In” Spring to Suit OEM Retainer
Any concerns with OEM base / retainer that would warrant replacement ?
RB25DET NEO Beehive Spring | Titanium Retainers
I know that Ti-retainers would be lighter / faster on valvetrain making it easier to move.
https://www.sau.com.au/forums/topic/484803-upgraded-neo-valve-springs/
13 hours ago, GTSBoy said:
Unless you're planning to turn 11ty rpm, there's no need to spend on jewellery like Ti retainers. If you're flush with cash, go ahead. It's good for the insta-likes.
Agreed, just was not sure if RBs had anything that would dictate recommending new base or retainer. Everyone recommends head drain due to oil pooling the head. Didn’t kno if there was a similar thing potentially for valve springs
Definitely do valve springs, on my old non-NEO motor, with 1.7bar of boost I would get valve float (power went flat, sounded like a misfire).
Current motor has Performance Springs springs & Ti retainers. Was about $200AUD more to get the retainers, so why not? Lol.. now I can tell @GTSBoy I have Ti retainers.
  • Like 1
These ones from golebys?
They're used quite a bit, however Kelford springs and cam combo would be a no brainer.
I went with this brand purely from a cost perspective on my last motor (not the 1st one) and carried them across onto the current motor.
  • Like 1
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
