RB26 boost leak? limp mode?
Rochester 1000cc injectors top feed low impedance working fine may need a clean worked well with e85 $450
Deatschwerks 1800cc these are new never used injectors retail is just over $1000 suit top feed injectors . Product information in pictures . $800
I've just had the world's best bad idea. We have fuel returning back to the tank. Just point some/all of it at the inside of the bulkhead fitting. Direct liquid cooling!
Hypothetical hat on.... I think they want to make sure that it is no more than 8.2mm to ensure that the 14mm hex electrical isolator washer thing stays outboard of the hole, so the o-rig on it seals properly, and they want as much room as possible between the passthrough bolt and the plastic lid, so that it can't touch the plastic and heat it. Even assuming that the steel should run cold enough to not be an issue, they are probably applying additional paranoia in case of the sorts of crimp/terminal problems we're thinking might be at play in your situation.
Just looking at the instructions for these Efi hardware terminals, is anyone able to explain to me why the diameter of the hole must be specifically between 8.1 and 8.2 mm? If the post is 6mm, and you drill say a 7mm hole, how could this possibly cause an issue? In any case, the more I read these instructions, the more I think I want to give them a go. https://www.efihardware.com/download/237/866-033_M6_Bulkhead_Terminal_High_Amp
