RB26 boost leak? limp mode?
I just remembered I got like intermittent rpm drops on idle a couple weeks ago but that's gone now
I'll do a compression test on the weekend with the headgasket test. here is a youtube like with the idle:
Is it factory looking? If so, have you looked at the wiring diagram?
Hello all what is the 4-pin connector in the picture which is highlighted in blue? The one beside the yellow rca connector? What is it used for?
Rochester 1000cc injectors top feed low impedance working fine may need a clean worked well with e85 $450
