Hey all,
I'm a long time forum reader, but have only just signed up.😬
I have a simple question and hopefully one or some of you can assist.
I don't believe I found a definitive answer by searching, possibly as its not a common question or even possible.
Question:
I have a Nismo Front pipe, I believe the inlet is twin 2.5inch pipes into 3inch outlet.
I am presently removing factory twins to replace with -9/GTSS twins.
Naturally, this has made me consider upgrading/replacing the R32 GTR dumps.
I appreciate it's debatable if it's worth doing from a performance vs cost perspective when sitting around 300kw mark, but I thought I should explore anyway for due diligence.
Seeing as my front pipe is 2.5 inlets, what dump pipes would be suitable?
They all appear larger than 2.5inch, does this create an issue when bolting together or do I simply end up with an internal step down (lip)?
The closes match is the HKS ones, but from what I understand these are not recommended due to design/performance constraints.
In a perfect world, I would opt for a HPI dump or Tomei, but hence my question I am not sure if it's possible with a 2.5 inlet front pipe.
With all things considered, it makes me think to not bother with any, as I'm not interested in replacing my Nismo front pipe to accommodate dump pipes.
Perhaps factory dumps are the best for my intended purpose/power level of 300kw - 320kw?
On a side note if anyone has some 34 dump pipes, please can you kindly message me? 🙏
Thanks in advance.
It's been a really long time since I've looked at the standard dumps, and you didn't mention a measurement for them, but from memory they are very small and probably one of those deliberately easy to fix restrictions that the car came with to keep it to "206kw". I remember the R34 ones were better but don't have their measurement handy either
I'd change them out for sure, the HPI ones are good price/performance and give a 76mm outlet, which I can see is larger than your 63mm front pipes but I don't see that causing a problem, the front pipes will just be the restriction.
Thanks for reply Duncan, really appreciate it.
I believe the 32's are 54mm. The 34's are possibly 60mm from what I have read. But, don't quote me on that one.
Thank you also for confirming re dumps into front pipe as far as sizing is concerned.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
